Maniflow Large Bore Lcb - Ground Clearance
Posted 16 January 2021 - 10:16 AM
Is anyone here running a large bore LCB and able to check their ground clearance for me please?
I've got a Mini here with one fitted and the ground clearance with a 1-7/8" maniflow twin box system is poor, particularly at the y-piece and join to the exhaust.
To put some numbers to it...
The Y-piece is only 74mm off the ground.
The underside of my clamp onto the exhaust is 52mm.
The front sill height is 215mm.
Admittedly the car is sitting a bit too low anyway and the 10" wheels don't help. The whole car could be lifted increasing the 215mm to more like 230-240mm but the manifold does seem to hang very low anyway.
Is anyone able to measure their clearance and sill height to compare to mine please?
Posted 16 January 2021 - 11:04 AM
Which part number is it? They do make a few different large bore manifolds.
Posted 16 January 2021 - 01:43 PM
With all the road humps and sped cushions around these days it is easy to damage the exhaust if the pipes and silencers are too close to the ground.
Posted 16 January 2021 - 02:11 PM
Posted 16 January 2021 - 02:37 PM
Posted 16 January 2021 - 09:30 PM
I think you've identified your real problem, the car is too low. Raise it up again and all those issues pretty much go away. I know "slammed" is the style everyone aspires to today... I prefer a good ride and being able to pull into my drive without dragging anything.
Posted 16 January 2021 - 09:50 PM
my large bore race LCB CLM005SIII almost flush with the floor pans.
Posted 16 January 2021 - 10:08 PM
Posted 16 January 2021 - 10:10 PM
Posted 16 January 2021 - 10:36 PM
I have to say that my old 1995 year medium LCB was not far off what this one is. Mine have always been close to the floor.
Posted 16 January 2021 - 10:44 PM
Posted 16 January 2021 - 11:06 PM
Maybe they've pulled them up a bit higher in recent years. This one is a 1999/2000 vintage!
My one before that was similarly positioned is older than yours.
Posted 16 January 2021 - 11:16 PM
Posted 16 January 2021 - 11:46 PM
High like my current one.
Posted 17 January 2021 - 09:00 AM
Been running a maniflow largebore long 3 into 1 since 1990 that sits high and snug like Nick's but with the centre pipe coming in beneath the two outer pipes.I think that's got just over 2" of ground clearance and my ground to front sill height is 185mm.
