One thing to think about is what engine you have. If you have a small bore then that block is shorter than the 1275 one so will sit a bit lower.
Maniflow Large Bore Lcb - Ground Clearance
danc
, Jan 16 2021 10:16 AM
20 replies to this topic
#16
Posted 17 January 2021 - 11:09 AM
#17
Posted 17 January 2021 - 12:45 PM
Yes, those with a 3-pipe Y-piece are designed for racing where the volume of exhaust gas is higher because of the high revs. It was never intended for road use.
#18
Posted 17 January 2021 - 12:47 PM
The exhaust on a 1071 S sits 1/4" lower than on a 1275 using the same manifolds.
#19
Posted 17 January 2021 - 01:07 PM
Thanks all for the comments.
This is a 1275 block, rod change sat in a single bolt subframe - nothing out of the ordinary going on.
The last two medium bore Maniflow LCBs i fitted were awkwardly close to the floor, but fine and nicely snug once in position. This particular one (definitely a large bore Maniflow) looks very poor in comparison.
#20
Posted 17 January 2021 - 05:17 PM
Are you sure it is a Maniflow one?
#21
Posted 17 January 2021 - 09:39 PM
I was dead sure until very recently! :) I've never used anything other than Maniflow and didn't know anyone else did bigger LCBs.
If anyone has the time to check some outer diameter numbers, I'd be grateful...
My outer primaries are 1.5"
The centre one is 1.625"
Both diameters entering the Y piece are 1.625".
The Y piece collector is 2"
