Twin S.u Hs2 Carb Float Lid Holes.
29 replies to this topic
#1 PACINO
PACINO
  • 764 posts
Posted 18 January 2021 - 04:42 PM
Hello everyone! In my 1275cc engine I have a twin Hs2 carb that I bought second-hand and of unknown origin, the breather holes are different.
On the left side, the hole float lid is big as this one (pic).
On the right side, the hole has a much smaller diameter. Maybe less than half.
Is this ok for a good performance?
#2 sonscar
sonscar
  • 3,032 posts
Posted 18 January 2021 - 05:09 PM
the big one probably had a pipe in it.the small ones I have have a metal cover over them,rubbish could get in.Steve..PS I see you have the covers,will be ok.
Edited by sonscar, 18 January 2021 - 05:10 PM.
#3 PACINO
PACINO
  • 764 posts
Posted 18 January 2021 - 05:33 PM
I appreciate the answer but you have not clarified my doubts. The question is clear. Must the holes on both sides have the same diameter?
I say this because this Twin Carburettor has 'never' been quite right. I feel the engine with a lack of gasoline that only improves when I pull the starter or when the engine has already reached its correct temperature. And I suspect this could be the problem.
Regards, Luis
#4 goudoogje
goudoogje
  • 94 posts
Posted 18 January 2021 - 06:03 PM
This hole is there, so that the fuel bowl can "breathe" (else it can not fill up with fuel because of trapped air). I am no expert on this matter, but I doubt if a bigger non matching hole will impact performance.
To be sure, replace it, or make the other hole bigger to?
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 18 January 2021 - 06:37 PM
If you have carb problems as you say "Not Quite Right" then its going to be down to mixture setting or the wrong needles for the application, thats assuming you don't have air leaks and the rest of the engine is in good order. What does not quite right mean ? flat spots ?
#6 PACINO
PACINO
  • 764 posts
Posted 18 January 2021 - 06:58 PM
Cheers man. I thought precisely that. Drill and make the hole bigger. But what if the worst! Do you know what that cover of the first photo in Burlem cost me? They are very expensive items.
#7 PACINO
PACINO
  • 764 posts
Posted 18 January 2021 - 07:13 PM
[quote name="KernowCooper" post="3680773" timestamp="1610995077"the engine is in good order. What does not quite right mean ? flat spots ?[/quote]
Thanks for reply. The needles are correct. GY code. If you try to fit sometíng richer, M or AH2 for example, the car goes worse.
I've bought a new float lid because I thought the hole was too big, and often the gasoline would overflow leaving that greenish color on top. In addition, the sound of the engine is bad until it is already hot, it dilates, and all the fuel it needs enters it. So the sound is round and it sounds like a real Austin Mini.
When today I got the new float lid and I saw that it also has a large hole, I told myself perhaps the correct hole is the big one, and the cover on the other side with the small hole is the one that does not correspond to this carburetor.
So what is the correct diameter?
Regards
Edited by PACINO, 18 January 2021 - 07:22 PM.
#8 floormanager
floormanager
  • 710 posts
  • Local Club: Mini Club Sussex
Posted 18 January 2021 - 07:19 PM
You got the correct springs in the dashpots?
#9 richmondclassicsnorthwales
  • 942 posts
Posted 18 January 2021 - 07:20 PM
You could find that the particular hole has being slightly increased and drilled.
The baffle holes are quite small, and could have got bunged up with sediment, and someone made a size increase. The standard hole was sufficient, but aluminium does have a habit of growing grime with condensation and damp
The baffle covers will however stop any s h one t getting in. The float lids are about £22 with around £6.95 postage as an idea.
Personally - I would not worry about it. It is only a breather hole, but just a bit bigger than the other.
If you are having mixture or petrol feed issues - then delve a bit deeper, but that hole won't really give you any problems, it is only to aid breathing.
#10 PACINO
PACINO
  • 764 posts
Posted 18 January 2021 - 07:24 PM
I think the springs are correct. Before reds and now blue ones.
#11 PACINO
PACINO
  • 764 posts
Posted 18 January 2021 - 07:29 PM
Hi friend! Do you mean with "The baffle holes" to these holes I'm talking in the post or something different?
cheers
#12 PACINO
PACINO
  • 764 posts
Posted 18 January 2021 - 07:30 PM
cheers
#13 richmondclassicsnorthwales
  • 942 posts
Posted 18 January 2021 - 09:05 PM
Si, agujero del deflector, Por favour
My Espanola no es tan bueno como 25 años cuando vivía en lloret de mar
Edited by richmondclassicsnorthwales, 18 January 2021 - 09:11 PM.
#14 PACINO
PACINO
  • 764 posts
Posted 18 January 2021 - 09:16 PM
Well, I've paid a little more. 50pounds included VAT + shipping to Spain.
https://www.morrismi...oat-hs2-p830672
Regards
#15 PACINO
PACINO
  • 764 posts
Posted 18 January 2021 - 09:19 PM
jajaja! Your spanish it's not too bad.
Gracias amigo!
