New Diff Bearing Install Issue
7 replies to this topic
#1 sam138
sam138
  • 521 posts
Posted 19 January 2021 - 09:17 PM
Just wondering if someone could have a listen to the video below, I’ve fitted a set of new RHP diff bearings to a new x pin diff unit but they don’t sound right at all. Should there be any sound at all when you spin the bearing by hand ? I’ve got one that makes a noise and doesn’t rattle and another one that rattles if you shake side to side but smooth when spun.
Attached File  trim.A61B6CB4-6556-4D72-9FC9-C0C1F99C8D39.MOV   1.73MB   21 downloadsAttached File  63278407158__C1F1BB33-F5E2-4709-AF51-71A96F4002F5.MOV   591.73K   7 downloads
Edited by sam138, 19 January 2021 - 09:23 PM.
#2 MiNiKiN
MiNiKiN
  • 217 posts
Posted 20 January 2021 - 08:21 AM
Pretty difficult to judge without fingering it - could be that one has some grease in and the other being dry?
wash them both with brake cleaner and blow-out gun and spin them again, if my above guess is true they will both sound the same.
by the way: Did you press/knock them on via outer or inner race?
Edited by MiNiKiN, 20 January 2021 - 08:23 AM.
#3 Spider
  • 15,684 posts
Posted 20 January 2021 - 08:48 AM
Your clips came out a bit quiet on my end, but what I was able to hear, sounded OK. They just sound dry.
These Bearing do have some free play / shake in them, that's normal and that's also why we pre-load them when fitting up in the Gearbox, to take all that play out of them.
#4 sam138
sam138
  • 521 posts
Posted 20 January 2021 - 10:18 AM
Thanks for the reply, I knocked them in with a socket on the inner race, I’ll give them a clean out and check again.
#5 Dusky
Dusky
  • 5,322 posts
Posted 20 January 2021 - 11:23 AM
He...he...he...
#6 MiNiKiN
MiNiKiN
  • 217 posts
Posted 20 January 2021 - 12:50 PM
He...he...he...
Don't we all love some ambiguity :lol:
#7 sam138
sam138
  • 521 posts
Posted 21 January 2021 - 05:41 PM
I’ve cleaned them out and re oiled them as suggested, not sure if I’m being paranoid but I’ve attached the below video which shows one of the bearing noises and not sure if this is just vibrating through the diff unit itself as it feels like it ?
How would I know if it’s faulty ?
Attached File  63294364355__658D6B5B-C2AB-4561-B202-0D049F1756C0.MOV   851.32K   14 downloads
Edited by sam138, 21 January 2021 - 08:53 PM.
#8 MiNiKiN
MiNiKiN
  • 217 posts
Posted 22 January 2021 - 09:53 AM
Once they are properly cleaned with brake cleaner or paraffine, check the races and balls for any signs of spalling
Remember that unlubricated bearings always make akward noises - and just as a warning: never spin them using your blow-gun ;)
