Hydrolastic bleed/fill valve thingy
Gibbon
, Nov 02 2006 05:21 PM
6 replies to this topic
Posted 02 November 2006 - 05:21 PM
Where would one obtain a pair of these wonderful items ????????????????
Posted 02 November 2006 - 07:12 PM
found one bit.
http://www.minispare....aspx?pid=33197
tryed moss to they got no wet suspernsion parts....soo...errm....your bugged to a degree.
Edited by Big_Adam, 02 November 2006 - 07:12 PM.
Posted 02 November 2006 - 07:49 PM
whats wrong with the 1 in the pic then?
Posted 02 November 2006 - 10:59 PM
Thanks for the link, unfortunately I need the whole unit, not just the bleed valve.
Both of mine are knacked (
Posted 02 November 2006 - 11:05 PM
Try Tim at Minimail
Posted 03 November 2006 - 12:00 AM
I haven't worked on a wet Mini so can you fill me in on the valve and fittings above?
I thought I was told that the valve shown above was just a high-pressure version of a Schraeder valve. If that's true you should be able to source the part from an industrial hydraulics supplier. Likewise, the other two fittings look like you could probably find parts at a hydraulic supplier that would work well as substitutes.
Posted 03 November 2006 - 08:24 AM
I tried this Google Search and Minimail are top of the results, but their website is down. Tried last night and again this a.m. and it's still down.
dkl : the bleed/fill units are fitted on the back of the rear subframe, you use one of these to pump up the suspension. Your remarks about hydraulic suppliers are interesting, I will follow up on that one.
There are plenty of hydraulic suppliers in my area (very agricultural in this part of France) but I suppose there's no point contacting them as all their threads will be metric and the fittings won't correspond with imperial threads ??? Sourcing from the UK must be the best option
