Led Converted Headlights Will Fail Mot
39 replies to this topic
#1 Revd
Revd
  • Just Joined
  • 81 posts
Posted 27 January 2021 - 07:01 PM
As of 1 January 2021, section 4.1.4 of the MOT Inspection manual reads: “Existing halogen headlamp units should not be converted to be used with high intensity discharge (HID) or light emitting diode (LED) bulbs. If such a conversion has been done, you must fail the headlamp.”
-from the Daily Telegraph 27th January
#2 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 27 January 2021 - 07:27 PM
Interesting, and not that I have done it, but I wonder what the reasoning behind that is
#3 beardylondon
beardylondon
  • 1,814 posts
Posted 27 January 2021 - 07:43 PM
It’s been the case for a while, just now it’s in black and white
https://www.autobulb...egal-in-the-uk/
#4 nicklouse
  • 19,067 posts
Posted 27 January 2021 - 07:49 PM
Was posted on here a few weeks back.
#5 Shooter63
Shooter63
  • 1,298 posts
Posted 27 January 2021 - 08:32 PM
I have posted about this on another site, but I expect its because of the dazzling of on coming traffic, a LED emits light in a 120 degree pattern, you either need a reflector that concentrates the beam which makes the simple changing of the bulbs for an upgrade redundant or you have to lens the bulb itself to focus the beam ( which I've never seen for sale for automotive use)
Shooter
#6 mini-mad-mark
mini-mad-mark
  • 926 posts
  • Local Club: northants wot no brakes
Posted 27 January 2021 - 08:34 PM
Can you get away with it if your mini was originally on candles sealed beam units as it specifically states Halogen not SBs
#7 beardylondon
beardylondon
  • 1,814 posts
Posted 27 January 2021 - 08:43 PM
These suggest same beam angle / pattern
https://www.classicc...onversion-9-32v
#8 Tornado99
Tornado99
  • 750 posts
Posted 27 January 2021 - 08:58 PM
I guess the work around is to fit lamps which come with LED's already, not Halogen converted. There are several 7" fully complete LED units out there for various cars/bikes.
#9 imack
imack
  • 2,382 posts
Posted 27 January 2021 - 09:08 PM
Doesn't matter what the car was originally fitted with, what you're not allowed to do is fit a LED (or HID) into a lamp unit originally designed to take a halogen bulb.
#10 Pops_Guild
Pops_Guild
  • Just Joined
  • 363 posts
Posted 27 January 2021 - 09:17 PM
So i have the ClassicCarLED warm light LED replacements in mine. They passed MOT in November 2020 even after I brought it to the testers attention, he said they were very good, he couldn’t tell. Of course now it’s black & white it will be different when I go again. Not arguing with that
However the ClassicCarLED ones seem different to the ones everyone hates, they do make a good fist of making a comparable light beam to the halogens. They work well and the light beam is good and far as I can tell, not dazzling.
...but come Nov 21, if I have to go back to Nightbreaker I will.
#11 imack
imack
  • 2,382 posts
Posted 27 January 2021 - 09:47 PM
If they give the right beam image and they're not obvious normal LED cool white then they may go unnoticed. Especially if your head lamps happen to have a shield covering the bulb so it can't be seen as my old lucas H4's have. I don't run leds by the way.
#12 Pops_Guild
Pops_Guild
  • Just Joined
  • 363 posts
Posted 27 January 2021 - 10:22 PM
Mine aren’t particularly hidden, they’re Quadoptics. We will see.
(edit) can't for the life of me get the photo to display in the correct orientation...so apologies
Edited by Pops_Guild, 28 January 2021 - 12:00 AM.
#13 Pops_Guild
Pops_Guild
  • Just Joined
  • 363 posts
Posted 27 January 2021 - 10:25 PM
These are what the LEDs from ClassicCarLEDs look like by the way
Edited by Pops_Guild, 28 January 2021 - 12:02 AM.
#14 Kombi
Kombi
  • 105 posts
Posted 28 January 2021 - 02:16 AM
If I were to guess they're restricting the use of them because they're most often installed inappropriately which makes their light output dangerous for oncoming drivers.
#15 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 28 January 2021 - 07:24 AM
I imagine it's because they're so many badly designed LED headlight bulbs out there. The manufacturers haven't considered (or cared) what a bloody nuisance a badly designed product is.
