Head Replacement
Best Answer Jaffamini , 02 April 2021 - 03:07 PM
Hi thanks all for your suggestions, checked everything and found dizzy to be out, timming way out. Don't get why as I never touched that. Still running now, sweet as a nut. Regards kevin Go to the full post
Posted 06 March 2021 - 07:10 PM
Posted 06 March 2021 - 07:14 PM
148 seems a tad low.. have you reset the tappets?
Posted 06 March 2021 - 07:58 PM
Posted 06 March 2021 - 09:26 PM
Did it run before you pulled the head off?
Posted 06 March 2021 - 09:53 PM
Posted 06 March 2021 - 09:56 PM
Check tappets
Use the rule of nine
Posted 07 March 2021 - 06:54 PM
Posted 07 March 2021 - 06:55 PM
Posted 07 March 2021 - 06:59 PM
Posted 07 March 2021 - 07:07 PM
How fresh is your fuel, past 6 months it will be pretty low in octane - worse than what you buy it now at the pumps.
Try some easi start whilst cranking, if it fires and runs momentarily while you are getting someone to do the honours of spraying easi start, there is a bit of a clue.
You need just 3 things for an engine to run - spark - in the right place - fuel and air
Posted 07 March 2021 - 07:15 PM
Posted 08 March 2021 - 07:23 AM
Edited by croc7, 08 March 2021 - 07:27 AM.
Posted 08 March 2021 - 07:49 AM
Check dizzy cap is on the right way around. Take the dizzy cap off, rocker cover off and check that rotor arm is pointing to cylinder 1 when it's on its compression stroke (valves closed at TDC).
Posted 08 March 2021 - 08:23 AM
Is the new head cracked and letting water in? Are plugs wet with petrol or water? Had a similar problem with an MGB head last year.
Posted 08 March 2021 - 08:25 AM
See my comments of your post earlier that day.
