Hi,
Im sure this has been asked a million times but did a search and can't seem to find a clear answer.
I picked up an A- 998 engine to rebuild today which originally had a remote box. I have a rod change box from another A- 998. Will tye rod box fit straight on?
Rod Change Box On Remote Block
nzjb
, Mar 07 2021 03:46 AM
3 replies to this topic
Posted 07 March 2021 - 03:46 AM
Posted 07 March 2021 - 06:53 AM
Only if you have the transfer case with it.
Posted 07 March 2021 - 08:06 AM
Cheers, I do have the transfer case so that makes it easy
Posted 07 March 2021 - 08:08 AM
Only if the Rod Shift Box is a later one with the Larger Idler Gear Bearing, even then, you cam fit an adaptor.
