Head Gasket Components Worth Buying
22 replies to this topic
#16 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 17 March 2021 - 08:39 PM
I think he means dump it in a river with a vice attached, to sink it :proud:
#17 ads7
ads7
  • 351 posts
Posted 17 March 2021 - 08:49 PM
Determined to get some reliability from this little engine.
Although I'm about to pick up an 1100 as a spare motor to build up slowly I still don't want to give up on the 850 as it will feel like I've wasted a potentially serviceable unit that could still do its job for at least the next few years.
It's running 65 lbs oil pressure from cold so I know the bottom end is all ok. It doesn't use loads of oil and the bores are smooth with no lip although it will at some point need a hone and new rings but hey 850s are so low stressed they can run over 100k before needing a rebuild.
I've got this little dream of doing a trip to Austria next year with luck it can actually happen
#18 ads7
ads7
  • 351 posts
Posted 17 March 2021 - 08:50 PM
#19 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 17 March 2021 - 08:52 PM
To be fair you really cant rule anything in or out as a cause of the failures if you are using a "crap" torque wrench.. I know lots of people me included who do not use a torque wrench for most nuts and bolts... for me there are three areas where a torque wrench must be used.
1. Head
2. Flywheel
3. Wheel nuts
And if you must use one for these 3 items, it must be accurate or you defeat the whole point in using one in the first place
#20 Dusky
Dusky
  • 5,322 posts
Posted 17 March 2021 - 09:12 PM
Nothing wrong with those bendy torque wrenches. Just check it’s calibration with a Vice and a bucket of water.
https://youtu.be/lZUDH13yln0
I was going to type it out, but this is easier
#21 ads7
ads7
  • 351 posts
Posted 17 March 2021 - 09:23 PM
Thanks I'll give that a watch. My torque wrench is one of those bendy pole jobs with a pointer... Probably inaccurate as hell
#22 Dusky
Dusky
  • 5,322 posts
Posted 17 March 2021 - 10:44 PM
They’re not necessarily bad, they’re a lot more accurate than some cheap spring type wrenches. I use the pole ones for diff rebuild on us cars
#23 MiniMadRacer
MiniMadRacer
  • 892 posts
Posted 18 March 2021 - 09:35 AM
I perhaps should have added (but didnt as its not something most people do at home), torque wrench for big ends and main caps too
