Additional Fuse Box
16 replies to this topic
#16 sam138
sam138
  • 509 posts
Posted 06 May 2021 - 06:58 AM
Hi,
I’ve completed the wiring as per pictures attached however I’ve put the battery in and turned the ignition on to find that the additional fuse box items only come on when I put my dip beam lights on.
Would this be to do with where I’ve connected the switch live to the existing fuse box ? As picture shows the cable on right of fuse box I’ve put in the bottom connector and this acts as the ignition live to new fuse box, is this correct ? The other cable unplugged on left hand side third down is my power to my converted central speedo unit.
The relay must be working as I pulled out the ignition live from old
Fuse box and my fuel pump and gauge goes off.
Any help please
Attached File  B7486581-8BEA-4079-A158-18EFB62BC67F.jpeg   104.01K   0 downloads
Attached File  D3EEF4F8-2C36-4351-89F7-7040E3B603FE.jpeg   117.47K   2 downloadsAttached File  D3EEF4F8-2C36-4351-89F7-7040E3B603FE.jpeg   117.47K   2 downloads
Attached File  AB05771E-BE17-49DA-ACC9-A0CE958F34C9.jpeg   101.19K   2 downloads
Edited by sam138, 06 May 2021 - 06:59 AM.
#17 johnR
johnR
  • 2,305 posts
Posted 06 May 2021 - 07:49 AM
You ought to get one of those cheap power probes - basically a crocodile clip on one end of a wire, with a small bulb holder with a metal pointer. You put the clip on an earth and can then use the pointer to check any connections for live (or vice versa) They're invaluable for car electrics.
