Hello all,
I am looking for some technical advice regarding gearboxes, bearings, and gear sets. I am undertaking a rebuild of an A+ gearbox for the restoration I am doing on my mini. I have stripped the box and found that one of the gears on the lay gear is a bit worse for wear and I should probably invest in a new lay gear... only to find the 30/26/21/15 set that my gearbox uses is very difficult to find.
I am wondering if there is any other lay gear that fits the box that's more readily available, I have seen A+ gear sets that are 31/27/21/15 but am unsure if this is suitable. I have also seen there are conversions to the CR sets but don't know what I would need to complete the task, ideally, I just want to invest in a new lay gear as I already have a rebuild kit on its way. Any advice would be much appreciated. Just in case anyone needs to know, the engine is a 998.
Also, I found this (see images attached) bearing on the first motion shaft, I don't know what its called or where to buy one, I haven't found anything that looks the same online, if anyone knows what it is that would be good to know too :) thank you.
