Clutch/gearbox Issues
6 replies to this topic
#1 Winniethemini
Winniethemini
    Just On Tickover
  • 5 posts
Posted 07 April 2021 - 01:09 PM
Hello all.
I recently purchased a non-running 1978 1275gt Clubman.
We have got it running but having a few problems with the hydraulic clutch system.
We have replaced the slave cylinder, and most associated pipework. Bled the system twice but I am still loosing pressure at the pedal. It comes back after pumping the clutch but disappears again.
Whilst tinkering with it at the weekend, it developed a noise that sounded like it was coming from the bell housing and disappears when the clutch is dipped.
Can anyone give me any ideas, I would love to drive Winnie the Mini this summer 😊
Thank you
#2 Lplus
Lplus
  • 911 posts
Posted 07 April 2021 - 02:56 PM
Sounds like the master cylinder seal is worn out and the noise from the clutch could be the throwout bearing.
#3 Winniethemini
Winniethemini
    Just On Tickover
  • 5 posts
Posted 07 April 2021 - 04:36 PM
Thank you for your reply.
I will give the master a bit of TLC and that should hopefully solve that problem.
Forgive my ignorance but I am assuming its an engine out job to replace the bearing?
Thanks for your help.
#4 sonscar
sonscar
  • 3,044 posts
Posted 07 April 2021 - 05:19 PM
If you really want it to be.Steve..
#5 cal844
cal844
  • 9,643 posts
  • Local Club: TFMOC
Posted 07 April 2021 - 05:36 PM
Clutch thrust bearing can be done in place
#6 Lplus
Lplus
  • 911 posts
Posted 08 April 2021 - 11:43 AM
As said above the throwout bearing can be changed with the engine in - just support the engine and remove the end cover and mount.   Though some of the bolts can be a real pain to remove. :xxx: :xxx: :xxx:
#7 Winniethemini
Winniethemini
    Just On Tickover
  • 5 posts
Posted 08 April 2021 - 12:31 PM
Thanks guys, those bell housing bolts are fiddly little so in so's  :mmkay:
