I need to make up a vac pipe for my new brake servo and have hit a snag. The take off that minispares sell won’t fit as it clashes with my air box, so I need to use the bango bolt that the later cars used, see link.
http://www.minispare...ssic/2A715.aspx
My question is what size banjo do I need to suit this bolt?
Brake Servo Vac Pipe Banjo Size.
humph
, Apr 11 2021 07:08 PM
4 replies to this topic
Posted 11 April 2021 - 07:08 PM
Posted 11 April 2021 - 07:24 PM
They used to be 5/8unf. Can't see any reason that would've chanced, but the temperature sender thread in the cylinder head is the same as a way of confirming.
Posted 11 April 2021 - 07:36 PM
Thanks Ethel,
So 5/8inch is just under 16mm, so a 16mm banjo should do the trick?
Just need to confirm what diameter the vac hose is now, I think the stuff I have is 3/8”.
Posted 11 April 2021 - 07:52 PM
Sounds right, bolt hole also close to 3/8bsp.
Posted 14 April 2021 - 06:16 PM
Listed same as the oil pipe banjo in front of block
