Partial Engine Number
7 replies to this topic
#1 BenSwan
BenSwan
  • Just Joined
  • 33 posts
Posted 11 April 2021 - 10:28 PM
Hi,
Is there any way of retrieving the engine number from this partial?
It's a 1275 A+.
What I can make out is:
9 100593
Left to the 9 is the edge of a 0 or 9.
I'm hoping something like the serial can point to the right engine code.
Edited by BenSwan, 11 April 2021 - 10:29 PM.
#2 62S
62S
  • 1,242 posts
  • Local Club: You must be joking!
Posted 12 April 2021 - 07:53 AM
I don't recall why I remember this but I'm pretty sure there was an earlyish A+ with a 12HC09 prefix.
#3 nicklouse
  • 17,945 posts
Not really.
but you can get close by putting the info into the Guessworks engine number decoder and see what options you have ending with the 9 and what looks like a 0 in front of it.
12H xxxxxxxxx have fun.
#4 wile e coyote
wile e coyote
  • 1,224 posts
Posted 12 April 2021 - 07:58 AM
Not with what you've got, it'd almost definitely start 12H - but if you carefully remove the remains of the plate and give it a nitric acid bath - it just may reveal some more characters the look to be missing (possibly just very lightly stamped between the 9 and the 1) - that with luck  and a teardown of the engine (assuming it's all original) - i.e checking what pistons, cam, diff and dizzy it has fitted should mean you stand a fighting chance  when running it through guessworks engine no. decoder ...
Having said all that the engine number is not that important anyway - you can have 123456789 if you so desire.... one of my engines was acquired without it's full plate -  so I stamped a blank with my mobile & postcode - DVLA took that with no issues (it was a few years ago so things may have changed but...)
Edited by wile e coyote, 12 April 2021 - 08:00 AM.
#5 BenSwan
BenSwan
  • Just Joined
  • 33 posts
Posted 12 April 2021 - 04:44 PM
Going off http://www.guess-wor...ech/engine.htm, with 12H, all 3 digit codes are eliminated based on being A+. So the 4 left, with 0 or 9 followed by 9 is:
12H A09
Source Vehicle : Metro Economy
Engine type & CC : A+ 1275 cc Transverse mounted
Fueling :
Engine features : Lucas 16AC alternator with -ve Earth
Gearbox features : Std. Ratio Rod Change gearbox with Pot Joints
12H B09
Fueling :
Engine features : Lucas 16AC alternator with -ve Earth 55 Amp Alternator Police Specifications Breakerless (electronic) ignition Mechanical petrol pump
Gearbox features : Std. Ratio Rod Change gearbox with Pot Joints 3.4:1 Final Drive
12H C09
Fueling :
Engine features : Pre-engaged starter
12H D09
Fueling :
Engine features : Pre-engaged starter Wide Ratio Rod Change gearbox with Pot Joints 1985 Requirements 1988 Model year Breakerless (electronic) ignition
I'll have a look at the alternator and starter later tonight. I think its all original.
Is any of the remaining easily ruled out? Or is there a way of knowing the Serial range of each Engine code?
The plate doesnt have any Code Suffix inbetween the Code and Serial.
Thanks for the help and advice.
Edited by BenSwan, 12 April 2021 - 05:44 PM.
#6 BenSwan
BenSwan
  • Just Joined
  • 33 posts
Posted 12 April 2021 - 07:32 PM
Looking further it has:
Pre-engaged starter
A127-55 alternator
65dm4 electronic distributor
Though I don't think it's going to help me crack the code.
#7 steeley
steeley
  • Just Joined
  • 623 posts
Posted 13 April 2021 - 07:37 AM
If you are stripping right down
A09 has 3.1 final drive, the others have 3.44 you could count the teeth on the crown and pinion
Attached File  5CD8D09B-C38A-42B9-9E4A-9628CCF26270.png   144.81K   5 downloads
#8 BenSwan
BenSwan
  • Just Joined
  • 33 posts
Posted 14 April 2021 - 04:56 AM
Thanks for pointing that out @steeley.
I will be doing a complete strip down after I finish the body work so this will definitely help.
