Hi,
I am prepping a subframe for my salvaged from a Metro, 1310 upgrade in my 1982 HLE 1000.
I will probably be using a Metro Air Filter Housing but may opt for a cone or pancake filter at some point.
I also have and want to retain, a vacuum gauge (obviously need a different spacer than the one I am currently using.
With this in mind, to allow for the larger HIF44 carb, what should I put in place to get the extra clearance?
A mod involving repositioning the engine mounting holes in the subframe has been suggested but I can't find any info on that?
I do believe I have an adjustable top engine stabiliser, in my box of bits to fit (the one that fits on the flywheel side of the block).
Many thanks
