Brake Servo Hiss
5 replies to this topic
#1 Richard_
Richard_
  • 239 posts
  • Local Club: ISMOC
Posted 26 April 2021 - 11:40 AM
Hi all -
I now have my 1989 998 Racing green edition in standard trim running quite smoothly.
On switching off I notice a hissing sound coming from the servo which lasts about 10 secs then stops.
I disconnected the servo and blanked off the vacuum hose at the manifold end - and no hiss.
I have replaced the plastic vac hose with new rubber vac hose and something still hisses.
I haven't taken the car out on the road yet due to lack of paperwork so it's hard to assess brake servo operation.
Whilst the hiss is not a problem in itself - I wonder if I have a problem within the servo somewhere. Possibly the O ring seal against the brake master?
Does anyone know if this sound is normal? or is there a loss of vacuum occurring which might cause a loss of braking assistance?
Many thanks.
#2 RooBoonix
RooBoonix
  • 1,224 posts
Posted 26 April 2021 - 11:45 AM
It's not normal. Did you replace the rubber grommet/seal in the servo body where the vacuum pipe elbow attaches? Part no, NAM8569
#3 Ethel
  • 25,438 posts
Posted 26 April 2021 - 11:50 AM
It's possible, the servo should hold on to its vacuum without the engine running. Roo's suggestion is the sensible place to start - you could also see if holding the brake pedal down makes a difference
#4 Richard_
Richard_
  • 239 posts
  • Local Club: ISMOC
Posted 26 April 2021 - 11:51 AM
No - and it seems pretty wobbly in relation to the steel servo body. The old plasticky vac hose had gone very rigid.
Tried to buy one from minispares but couldn't find one. That part number should really help - many thanks.
#5 RooBoonix
RooBoonix
  • 1,224 posts
Posted 26 April 2021 - 11:56 AM
http://www.minispare...ic/NAM8569.aspx
Limited stock apparently. Cheap part, seems the most sensible place to start before digging much deeper
#6 Richard_
Richard_
  • 239 posts
  • Local Club: ISMOC
Posted 26 April 2021 - 12:00 PM
Found the grommet on mini spares and ebay. Have ordered one.
Brilliant super-fast assistance as ever from the forum - thank you!
Edited by Richard_, 26 April 2021 - 12:02 PM.
