Standard 1098 Pistons
14 replies to this topic
#1 peasoup39
peasoup39
  • 97 posts
Posted 01 May 2021 - 12:52 PM
Looking for a set of  standard1098 pistons.
Minispares are out of stock , alternative supplies i have seen are hundreds of pounds or they are from abroad which may be dodgy.
Anyone got any suggestions.
There is a set on ebay of Hepolites at a reasonable price and i am enquiring as to the suitability of these in my 1978 engine
#2 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 01 May 2021 - 04:27 PM
Tried ESM Minors or any Morris Minor spares supplier? Same engine basically ...
Or FW Thornton's (not the choccy people) ...
Edited by gazza82, 01 May 2021 - 04:29 PM.
#3 peasoup39
peasoup39
  • 97 posts
Posted 07 May 2021 - 08:11 PM
Thorntons are over £400.00 per set so not keen on them.
Been told what i want is  Part number 20397 but not having much luck. These are 4 ring units
One supplier has offered 8G2441 as a replacement that superseded 20397 however these are 5 ring units with a ring near the bottom of the skirt.
These i believe are very old design from the sixties so not suitable for a later 1978 unit.  i was following a set on ebay with 5 rings which confirmed the earlier years
There are some pistons on ebay that look suitable but they only have 3 available
Can someone enlighten me please on the part i need and better still where i can get them sub £200.00
#4 Spider
  • 15,684 posts
Posted 07 May 2021 - 08:25 PM
I looked everywhere about 6 months back. I couldn’t find any in the UK that we’re eith 3 or 4 ring design or a decent price. I eventually found a set of NOS pistons from one of our local MG parts suppliers
#5 eric67
eric67
  • 120 posts
Posted 07 May 2021 - 08:46 PM
Do they have to be standard size? If you were to consider boring to +20, there is a set of 4-ring Karl Schmidt pistons available on eBay from a seller in Athens.
#6 peasoup39
peasoup39
  • 97 posts
Posted 08 May 2021 - 08:51 AM
Dont see the point in boring out a perfectly good engine if it is not needed. Cost wise rebore plus oversize pistons would be about the same price as the Thorntons pistons. so no real benofit
#7 sonscar
sonscar
  • 3,198 posts
Posted 08 May 2021 - 09:09 AM
What is wrong with the ones you removed,if indeed there were any fitted in the first place?In the grand scheme £200 is not much,£300 is getting salty.
25 years ago I had my Healey-Sprite 1098 robuilt and pistons were expensive and hard to source then.The rebuilder advised fitting a 1275 but I wanted to retain originality,live and learn.Good hunting,Steve..
#8 whistler
whistler
  • 1,870 posts
Posted 08 May 2021 - 10:42 AM
I might have a set from an engine I recently had rebored. I'll have a look shortly. What's the number on top of yours? I'm fairly local to you as well.
#9 peasoup39
peasoup39
  • 97 posts
Posted 08 May 2021 - 11:12 AM
Numbers on the piston are M2007   B38
My engine reconditioner has wire brushed them and they are very pitted around the ring grooves despite engine having only done about 57K. It was extremely Smokey when i bought it.to restore and  having stripped the engine i do not want to risk reusing them for the sake of £200.00 if that is what it cost for replacements.
#10 Cooperman
  • 23,513 posts
Posted 08 May 2021 - 11:33 AM
If the old pistons are scruffy and the engine was smoking, you might be best advised to consider a re-bore and new pistons.
From experience it is never wise to put new pistons into old bores. For the cost of a bit of machining you get peace of mind and a non-smoking engine.
#11 whistler
whistler
  • 1,870 posts
Posted 08 May 2021 - 11:41 AM
Set of 4 m2007
#12 whistler
whistler
  • 1,870 posts
Posted 08 May 2021 - 11:44 AM
Sorry about the blurry pics.
Message me if any good.
#13 peasoup39
peasoup39
  • 97 posts
Posted 08 May 2021 - 01:03 PM
My engine guy has checked the bores and honed them. There is negligible  wear hence his advice to stay as standard which i agree with. The problem of smoking was down to totally worn out rings which is a common fault. i can understand the scarcity of standard pistons as most bores are by now worn out and need to be rebored.
#14 whistler
whistler
  • 1,870 posts
Posted 08 May 2021 - 02:00 PM
Better piccie.
#15 peasoup39
peasoup39
  • 97 posts
Posted 09 May 2021 - 03:49 PM
The sets of pistons on ebay from Athens had a photo showing pistons were all plus 40 oversize so i ignored them. On closer inspection one set was  standard but he had used the same plus 40 picture for all of them. Just ordered a standard set at £90.00 plus £26.00 carriage so i think i have solved my problem. Happy with that result
