Engine spec:
1275 rebuild Cooper engine
MSE4 minispares head
Hif44 carb with BCA needle and 12oz spring
Eaton m45 suck through supercharger set up
Heater element fitted within air filter housing to aid carb icing
Facet solid state fast road pump and large filter king regulator.
I’ve linked below a few videos to show the initial attempts to start up.
After several times trying to start the air filter started leaking fuel from the bottom of paper section which i guess was because of over fuelling ?
I’ve got the fuel regulator set at 3psi is that correct? I’m concerned it needs more to get up the inlet pipe ?
I’ve attached a picture showing the breathe pipe from the supercharger which is attached to my non return brake servo pipe. Should I be seeing fuel out of this pipe from the supercharger when trying to start ? Just trying to work out if fuel is getting in.
I’ve also fitted one of Vmaxscart’s electronic distributors to replace my old points unit. I’ve also attached a few pictures which show this wired up. Black to negative and red to Positive of coil, I’ve also added the old cables either side on the coil as per before. I did originally have a cable that went from the car wiring to the the distributor via spade connector and had my Rev counter feed spliced in, should that be linked back up some how ? or I need to change the coil to suit the new distributor.
Any help would be much appreciated.
https://drive.google...ew?usp=drivesdk
Edited by sam138, 08 May 2021 - 04:12 PM.
