Brake Servo Or Master Cylinder With Brake Limiter?
17 replies to this topic
#16 sonscar
sonscar
  • 3,197 posts
Posted 08 June 2021 - 05:28 PM
I doubt it would be straightforward to fit ABS,adjusting the rear brakes on its own causes enough questions sometimes.Of course one mans problem is another's after lunch enjoyment.Steve..
#17 Dusky
Dusky
  • 5,322 posts
Posted 08 June 2021 - 07:14 PM
It won't only be hard, it will also brake a bit slower than the car with a servo. Yes, stopping power is limited by Tyre compound, but servo brakes build pressure quicker than manual brakes. Those few meters stopping distance could mean the difference between an expensive repair job and just a scary story.
#18 Ethel
  • 26,580 posts
Posted 08 June 2021 - 11:22 PM
Lots of vans have load sensing valves like you describe. An inertia valve is even better, it senses exactly what you need to reduce rear brake effort for.
has anyone tried adapting something like this to the Mini?
Ive also wondered why we never see ABS being adapted for older cars. Should be pretty straightforward as all components are available from other vehicles.
Inertia valve? They were standard eqpt on vans & pickups & possibly one or two other  Mini models before they got dual circuit brakes. Also found on other cars (Mk3 Escorts for one) before brakes got all electronic & complicated.
I'm pretty sure ABS is one of the no go areas for all but car industry big guns that get type approval on new built cars, same as airbags.
