Where To Get The Radiator To Body Foam Seal
Posted 01 June 2021 - 10:11 AM
Posted 01 June 2021 - 10:47 AM
http://www.minispare...98.aspx|Back to
that one will do.
I should probably be clearer, it is an 86 meaning it has no shroud on the body.
Posted 01 June 2021 - 10:52 AM
that one will do.
Don't think there was one on the later cars. Mines a '90 and there was never one on there.
If you have one fitted then it may have been a.modification by an earlier owner perhaps.
Posted 01 June 2021 - 11:03 AM
that one will do.
Ahhh it might have been a local production thing.
Posted 01 June 2021 - 12:47 PM
that one will do.
that one will do.
Maybe it was a Japanese thing, it does also have an electric fan inside the mudguard. I had thought that I previously found stuff on here about it but maybe I was getting mixed up with the earlier one as above.
Posted 01 June 2021 - 01:58 PM
I’ve never been able to source OEM ones, so I just made one up by using sheet rubber.
Posted 11 June 2021 - 08:37 PM
My RSP Cooper has a seal around the rad shroud that's supposed to line up with the lip on the body. It's more like fibre board than foam or rubber and is fairly distorted now but was designed to make sure all the hot air from the rad went out the inner wing grill.
Edited by pogie, 11 June 2021 - 08:38 PM.
