Mini Van Brake Servo
Posted 13 June 2021 - 07:09 AM
Posted 16 June 2021 - 06:08 PM
Posted 16 June 2021 - 06:37 PM
To my knowledge the mechanical parts are the same as the 'normal' minis, or more specifically the vans. You could probably fit an Mpi engine if you wanted unless you're going original?
Ben
Posted 16 June 2021 - 06:54 PM
Non power brakes have a proportioning valve eg my 87 with non power and he valve on the bulkhead.
You dont mention the year but the following link may help.
https://www.minispar...n.aspx?2~17~143
Posted 16 June 2021 - 08:47 PM
Not sure on this, but might make another post bump for you...
Ben
Ben is right. I had a 1980 van (LHD) and after a failing master brake cylinder I bolted in a later style horizontal brake servo with cylinder as you'd find in the later carbed and SPI's. I had to fit a new pedalbox, the linkage (driving LHD need extra linkage to engage the RH side placed servo). I all fitted withou any alterations: all holes where present and aligned..
So you can easilly fit a 90's or later servo setup into a 80's or any van..
Posted 16 June 2021 - 09:25 PM
Posted 17 June 2021 - 07:27 AM
Double rear doors are freaking awesome...
