Kad Quick Shift
16 replies to this topic
#1 GermanMoreno
GermanMoreno
  • 206 posts
  • Local Club: Mainly Minis Montreal
Posted 14 June 2021 - 07:05 PM
I tried installing one of the KAD Quick shifter, the latest type, and I couldn't get into 3rd or 4th gear. The shifter felt really really stiff on lateral movement from 2nd to 3rd. I was rocking the whole shifter box trying to find 3rd gear...
The regular shifter is buttery smooth, but really long throw. How do I trouble shoot this?
I will be replacing the roll pins first, but is there any other factor I need to take into consideration?
#2 Maccmike8
Maccmike8
  • 1,101 posts
Posted 14 June 2021 - 07:06 PM
Was it new?
#3 nicklouse
  • 18,705 posts
Posted 14 June 2021 - 07:07 PM
Most likely you are just trying to move it to far. The Gates are stupid close.
#4 Spider
  • 15,160 posts
Posted 14 June 2021 - 07:49 PM
There maybe a couple of adjustments needed, but first, take the bottom plate off the shifter housing and try it like that.
#5 GermanMoreno
GermanMoreno
  • 206 posts
Posted 14 June 2021 - 08:13 PM
Yes brand new, bought from Minispares
Was it new?
#6 GermanMoreno
GermanMoreno
  • 206 posts
Posted 14 June 2021 - 08:14 PM
that's a good idea, ill try that as well.
#7 dotmatrix
dotmatrix
  • 441 posts
Posted 14 June 2021 - 08:19 PM
I have a KAD gearstick on my rod box. I ended up taking some material out of the alu housing where he original ball sits to find all gears
#8 mpialan
mpialan
  • 118 posts
Posted 15 June 2021 - 06:10 AM
I found that a simple strap from the top of one of the rubber mounts to the bottom of the other, stiffened up the side to side location, improving movement between 2nd and 3rd.
#9 GermanMoreno
GermanMoreno
  • 206 posts
Posted 17 June 2021 - 01:45 PM
 Do you mean the eye rod extension? 22g2792?
#10 Tones61
Tones61
  • 434 posts
Posted 17 June 2021 - 08:18 PM
Bought mine direct from KAD,
Fitted right in,all gears mint :-)
#11 1968andyf
1968andyf
  • 144 posts
Posted 17 June 2021 - 09:18 PM
Had mine fitted for a few years now and it works well, but do remember it being stiff to move when first fitted so I relieved the nylon ball on the bottom of the stick a small amount at a time with a file till it was smooth
#12 GermanMoreno
GermanMoreno
  • 206 posts
Posted 19 June 2021 - 09:53 PM
I have been trying to undo the knurled collar, it’s hella tight. Does it actually control the stiffness of the shifter or is it there just to secure the nylon ball?
#13 Tones61
Tones61
  • 434 posts
Posted 20 June 2021 - 12:20 PM
Grease in the side nipple and work it a few times,
It'll loosen up a bit :-)
#14 1968andyf
1968andyf
  • 144 posts
Posted 20 June 2021 - 01:53 PM
No don't think the ring adds to stiffness, when I assembled it the ball was a tight fit in the alloy cup on a well used housing so relieved the ball instead of the cup. Would suggest as some one else has try it with the bottom plate removed so it easier to see and feel what is happening good luck
#15 GermanMoreno
GermanMoreno
  • 206 posts
Posted 02 July 2021 - 02:30 PM
Hi people, so I finally had the time to troubleshoot the QuickShift.
1- I removed completely the rod change box and replaced the rubber mounts that attached to the body of the car.
2- I reinforced the bushing that attaches the steady rod from the box to the transmission. It was a bit chewed up (the rubber that is sandwhiced) causing a bit of play.
3 - I also installed the quickshift outside the car making sure of all clearances were ok inside the box and bottom plate. Had to play a bit with this because the bottom of the quickshift was indeed touching the bottom plate of the box. I made sure I could move the shifter in every direction before putting it back onto the car.
4 - I installed the minispares slick shift bias barrel, it really pushes the shifter towards 3rd gear, so from 2nd to 3rd there is no guessing. I just push forward the shifter and its perfectly aligned to get into 3rd. When getting into 1st, you can really feel the spring's tension like in a modern car. It is a bit stiff for now, but I guess it will loosen up with time.
Very nice shifter indeed when you get it to work properly.
Thank you all for the help!
Edited by GermanMoreno, 02 July 2021 - 02:31 PM.
