Mpi Shell Rebuild
10 replies to this topic
#1 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 17 June 2021 - 05:42 AM
Currently have this green MPI shell that I am rebuilding for the owner. Came to be as a stripped bare shell. All the usual kind of panels needed for an MPI - full front end, scuttle, sills, door steps, rear panel etc etc...
As it came in -
Front end off -
Drivers inner wing was pretty bad so that has gone -
Door step off -
New one in -
New inner wing and A post on -
Edited by MiniJosh92, 17 June 2021 - 06:01 AM.
#2 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 17 June 2021 - 06:01 AM
Door re-skinned -
#3 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 25 June 2021 - 05:09 PM
Scuttle panel and front end on. All lined up well with little messing around which was nice for a change -
#4 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 15 October 2021 - 08:53 PM
I have been super busy most of this year so been a while since I updated this but have been getting there slowly with it.
Door steps, inner sills, seat crossmember, bottom of rear quarters, outer sills all replaced or repaired -
#5 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 02 December 2021 - 07:33 PM
Panel work almost finished. Hole in the boot floor for fuel lines repaired and all replaced around subframe mounting points and rear edge. Battery box, valance closing panels and valance replaced. Rear panel from below screen replaced -
#6 Jase
Jase
  • 1,166 posts
Posted 03 December 2021 - 12:46 PM
Nice work.
#7 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 24 January 2022 - 07:16 PM
Been a while since I updated this but, hopefully by the end of this week the shell will be ready to go for paint. Underside protected with sills and valances body colour then a lot of rubbing down to strip the exterior to bare metal ready for filler work, seam sealer and some etch primer -
#8 Avtovaz
Avtovaz
  • 1,257 posts
Posted 24 January 2022 - 08:08 PM
is that red oxide primer you are using? top work mate!
#9 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 24 January 2022 - 08:52 PM
Thanks. Yeah I do usually put some red oxide primer on the fresh metal and welds mainly just to protect it before the shell gets painted.
Edited by MiniJosh92, 24 January 2022 - 08:52 PM.
#10 MiniJosh92
MiniJosh92
  • 1,707 posts
Posted 28 April 2022 - 12:45 PM
Shell finished and back with the owner to be rebuilt -
#11 slidehammer
slidehammer
  • 1,196 posts
  • Local Club: LSMOC
Posted 29 April 2022 - 01:34 PM
Looks really good
