Plus 22% VAT, then DHL charge of £15 plus import charge, so it is not just a tenner
Why would they add VAT and an import charge between NL and Italy?
Yep. Nice and simple in the EU.
Posted 20 June 2021 - 06:49 PM
Posted 20 June 2021 - 08:09 PM
Primarily, If you buy something from the UK it should be VAT exempt if going overseas to an EU country
The buyer then pays the VAT at country rate - 22% in Italy 23% Ireland - 25% Sweden as example
Then the DHL admin fee of £15
Then import tax - if applicable or set out by the world trade authority, it is not the country that set it.
Don't shoot the messenger, This is what you pay if you buy from the UK in to an EU country.
I am just putting in the cost of a reamer from the UK, nothing moe.
Buying EU to EU makes sense,
£200 reamer, then add 44.00, then 15 plus import makes a no brainer
BREXIT eat your heart out !!!
Edited by richmondclassicsnorthwales, 20 June 2021 - 08:23 PM.
Posted 20 June 2021 - 08:33 PM
Posted 20 June 2021 - 08:56 PM
Nothing to do with the UK. have you not looked at their locations.
Posted 20 June 2021 - 09:03 PM
If he bought AC’s reamer it would be from the U.K. - that is what Richmondclassics is trying to show.
Edited by GraemeC, 20 June 2021 - 09:03 PM.
Posted 20 June 2021 - 09:07 PM
Thank you.
Posted 20 June 2021 - 09:14 PM
I would not get too hung up about reaming the bush. It is not like there is any spinning involved in this application. Even at maximum suspension travel it is only a few decrees of rotation. Fit both the roller bearing and the bush then dry fit the pin, it may well fit without needing any machining, the last few sets I fitted needed nothing. If you do need to "fit" the pin to the bush use a fine abrasive flap wheel in a drill. Go for something like a 19mm diameter 400 grit to polish out the bush.
Hand reaming requires some skill and knowledge in use. If you are going down the road of reaming use an adjustable type and only take off the minimum with each pass. Keep turning the reamer clockwise. never reverse, until it passes right through the bush. Use a good quality cutting oil to assist the cutting operation. Cutting too much off at a time or not passing the reamer through with a constant force can lead to a "wavy" finish to the surface and a ruined bush.
Posted 20 June 2021 - 09:20 PM
Posted 20 June 2021 - 09:32 PM
I give up !!
FORGET IT,
Just trying to outline the UK and EU barrier. Not bothering any more
Posted 20 June 2021 - 10:54 PM
Guys, let's not let this get political please.
Let the buyer make his own enquires, I think he's been made well aware of some of the possible pitfalls and costs, if there are any and I'm not getting in to that !
Posted 21 June 2021 - 08:42 AM
