Hi All,
I'm currently dry building my front end before she goes for painting and all is going well but I can't find a resource or guide to drilling the correct holes for the headlamp bowls in my carbon front end. The hole for the headlamps is there but I'm unsure what diameters and what location to drill for the bowl screws. Can anyone help? Cheers!
Headlamp Bowl Fitment - Carbon Front End
Surftolivelivetosurf
, Jun 20 2021 01:45 PM
5 replies to this topic
Posted 20 June 2021 - 01:45 PM
Posted 20 June 2021 - 03:50 PM
j
Just obtain a new headlamp bowl and use it as your template
Posted 20 June 2021 - 05:00 PM
Understood which I have done but what way is top and bottom?
Posted 20 June 2021 - 06:22 PM
Adjuster screws at top and left side of bowl?Memory dims but rim has a screwhole at the bottom?,Steve..
Posted 20 June 2021 - 07:40 PM
Hi, this photo might help?
For reference it's a Wipac bowl, the rim screw is just off vertical (around 5 ish mark if that makes sense) and its in the same position for both left and right.
Posted 20 June 2021 - 11:56 PM
That's really helpful and will set me in good stead. Thank you guys!
