Still haven't manage to get my ECU checked as we are still in lockdown.
But when I start the car sometimes, it is ok with my current ECU. But sometimes it is running rough as no firing on lead 2 and 3.
Could this be a faulty crank sensor?
It will not be a faulty crank sensor as it is only effecting one side of your coil pack.
The MNE 101351 is a dual plug ECU.
The smaller plug has 3 wires coming out of it.
The 2 black ones are unused in your car.
There should be a single white wire with a silver trace.
It is in position 18 of the small plug and runs direct to the bosch junior plug under your coil pack.
Your fault lies somewhere in this single circuit.
Check this wire and it's plugs each end for good clean connection and continuity.
The bosch junior crimp connectors are a bit fragile.
I'd be tempted to pull the ECU out of its bracket, pull the little plug and test pin 18 out of the ECU whilst turning the starter over.
No signal would confirm an ECU fault.
Please attend to the simple non ECU things first.
If it is the ECU I may be able to assist in repairs.
I may have a spare MNE 101351 in the coming weeks if I finish my Haltech project.
Regards
Waz
I have checked the wiring seems all good. Then I have tried to remove the small plug from ecu and tested the pin 18 with test lamp seems no supply. Can this conclude the ECU at fault?
The engine still misfire with or without the small plug connected to ECU as well.
At least we've got to the root cause now.
Like me in Australia you won't have access to repairers in KL.
You could try David Ainsley in Japan for a replacement unit.
I had an open circuit on my ATS Pin 16 on the larger plug.
An internal dry solder onto the back of the pin tang.
Pulled mine apart and resoldered and has worked fine ever since.
Mine was a nightmare to get too being in the second row of Pins.
The MEMS ECU's have an internal amplifier on the coil circuits.
Either you have a dry solder connection or the amplifier is gone.
The coil wire in your Pin 18 on the small plug is on the bottom row of pins and easy to get to.
There are no other connections on this small plug.
Good luck.
