Got smoke coming from the engine a bit on idle and quite a bit under load.
Theres reduced power running 3 cylinders 4 th kicking in under load replaced haed gasket, leads, plugs, oil filter and oil running better but still smoky my dad and gitlfriends dad think it's the piston rings?
Do you agree?
If so where and whichones do I buy?
1989 998 Piston ring?
DEVMAN
, Nov 06 2006 02:10 AM
6 replies to this topic
Posted 06 November 2006 - 02:10 AM
Posted 06 November 2006 - 06:43 AM
could try the valve stem seals before stripping the engine down just to do he piston rings.
could be worn bores aswell as rings so it could need a rebore
Posted 07 November 2006 - 11:34 AM
thanks mate anyone else have any thoughs?
Posted 07 November 2006 - 12:38 PM
Do a compression test buddy, if it is pants put a dash of oil down the bad cylinder and try again. If it's a touch better then the rings are no good. Other than that it could be valve stem seals or guides.
If you've got the cash then use it as an excuse to put a bigger engine in!
Posted 07 November 2006 - 12:55 PM
well I think I got some valve stem seals with my head gasket set. Are the easy to fit wil the haynes maual help me?
Posted 07 November 2006 - 01:20 PM
Bump
Posted 07 November 2006 - 01:23 PM
A Bump already....?
Did you try the compression test already as Dave suggested? I assume you must have done, what were the results? If not, then fitting the valve stem seals could be a waste of your time!
