Seats That Clear The Rear Bins - Suggestions Please!
10 replies to this topic
#1 JamesAlexander
JamesAlexander
  • 56 posts
Posted 21 July 2021 - 09:15 PM
Hi folks,
Having just fitted some SPI seats into my mini I’ve discovered they are hellishly uncomfortable as they are too close to the door and I can’t push them back as much as I need due to them hitting the rear bins.  I considered modifying the rear bins but thought I’d ask you guys and gals if you had an recommendations for seats that clear the rear bins to get maximum recline and leg room?!
I look forward to reading your suggestions, thanks in advance!
#2 mab01uk
mab01uk
  • 13,074 posts
Posted 21 July 2021 - 10:03 PM
Wood & Picket coach built Minis used to offer customers the option of cutting back the rear bins to give more clearance for those that required the seats further back.
I have fitted Recaro seats to my Mini (as fitted to some sports versions of Ford Cars in the past), they clear the rear bins ok even when fully reclined but I don't actually need the seats that far back for my best driving position.
#3 Cooper Mac
Cooper Mac
  • 222 posts
Posted 21 July 2021 - 10:43 PM
I’ve just got some Cobra Monte Carlo seats for my mini, there is plenty of clearance between the seat and the rear bin.
#4 Gabor
Gabor
  • 25 posts
  • Local Club: Mini Club Hungary
Posted 22 July 2021 - 06:44 AM
HI,
I am 192cm-s and pretty "wide", and I had the same problem. A friend of mine has cut the rear bin's top edge, straigt (cut the front the same height as the back of the bin), and that is enough and pretty confortable. I will cut it as well, but until I can make it, I added 4 washers to both sides to push the drivers seat to the center of the Mini, and that is enough for me.
G
#5 Bobbins
Bobbins
  • 1,526 posts
Posted 22 July 2021 - 07:59 AM
I've done the same as Gabor with my Mpi seats, if you mount the front leg inboard of the bracket and insert washers into the bracket itself, you gain a small amount pushing the rear leg against the tunnel. I then added a small amount of packing under the outside rear leg (under the carpet) having the effect of tilting the seat inwards slightly, not enough to notice when sat in it, but it does give a little extra space at the companion bins. Other than replacing the seats it's a case of incremental gains but it's surprising the extra you can achieve.
#6 Chris1275gt
Chris1275gt
  • 1,052 posts
Posted 22 July 2021 - 12:37 PM
I achieved that by drilling a hole between the rear locating hole and the centre hole on the bracket and put the locating bolt through that as above you don't notice it's slightly skew.
#7 Midas Mk1
Midas Mk1
  • 5,853 posts
  • Local Club: S.U.N.M.C
Posted 22 July 2021 - 05:09 PM
Ford rs turbo / escort cossy recaros quite possibly the comfiest most supportive seat i’ve had in a Mini.
#8 JamesAlexander
JamesAlexander
  • 56 posts
Posted 22 July 2021 - 08:46 PM
Great suggestions all thanks! I’ll try pushing them into the center before lobbing out the seats! Cheers!!
#9 Steve66
Steve66
  • 67 posts
Posted 23 July 2021 - 10:41 AM
Got Ford Puma seats in mine   Leather front and back and they fit with a small amount of modification. Clear the bins as well
#10 whistler
whistler
  • 1,897 posts
Posted 23 July 2021 - 11:00 AM
I have Puma seats in my 89. Best I've come across for the mini so far. Very good for long journey.
#11 JamesAlexander
JamesAlexander
  • 56 posts
Posted 01 August 2021 - 10:28 AM
Thanks folks!
