Woodruff Key Blocking Removal Of Timing Chain Sprocket
Best Answer postve , 28 July 2021 - 07:59 PM
Okay, let's just call this a wrap guys, instructions were clear and key has been removed - thx again
Have a wonderful evening!!
Go to the full post
20 replies to this topic
#16 postve
postve
  • 524 posts
Posted 28 July 2021 - 01:09 PM
So we filed it down and everything and still stuck after you hit the half way point
#17 postve
postve
  • 524 posts
Posted 28 July 2021 - 02:26 PM
Love taps and thx guys as always
#18 Tones61
Tones61
  • 428 posts
Posted 28 July 2021 - 03:05 PM
Think they meant file the sides of the woodruff key to allow the slot to slide over :-)
#19 postve
postve
  • 524 posts
Posted 28 July 2021 - 03:21 PM
Yes they did but unfortunately the key was damaged hence the reason to replace - always gotta do it correctly and no cutting corners - Plus learned a whole lot so one less thing to get soaked by a mechanic to do
#20 weef
weef
  • 489 posts
Posted 28 July 2021 - 07:29 PM
You seem to be having trouble understanding the information being given. Treat the key as a sacrificial part, push the gear back towards the engine backplate exposing as much of the key as possible. Now file down the exposed key to well below size to give pleanty of clearance. Slide off the gear, knock the key from the crankshaft and throw it away. Examine the shaft keyway for any damage and if all is OK fit a new key, seating it correctly and all should be well.
#21 postve
postve
  • 524 posts
Posted 28 July 2021 - 07:59 PM   Best Answer
Edited by postve, 28 July 2021 - 08:00 PM.
