Did you remove the flywheel / clutch?
FS
Posted 02 August 2021 - 08:18 PM
FS
Posted 03 August 2021 - 09:15 AM
Yes, the flywheel / clutch came out
new clutch plate
The old flywheel and pressure plate are unchanged, reassembled exactly as they were and back into the car in the only orientation that the keeway permits
Edited by Elwyn, 03 August 2021 - 10:30 AM.
Posted 04 August 2021 - 08:00 PM
Update
Crank sensor replaced
No change
Still won't start
I changed the injector
I have a spare
When I took the injector out, when I pulled it out of it's tight vertical housing at the top of the throttle body, it was covered in fuel
The gap between the injector and the housing was wet with fuel
When I pulled the injector out, this excess fuel sloshed out and down onto the top of the closed butterfly
I replaced the injector, tried gain, no engine bang
Went back to the second injector and found the same thing, ie it was covered in fuel
Fuel is going around, not through the injector?
Or is what I found normal and to be expected?
With 2 separate injectors?
There's a semi spherical yellow "hat" that sits on and provides power to the injector
Sorry for the terminology
There's an O ring that sits between the yellow hat and the vertical metal tube / housing that the injector sits in
Again sorry
This O ring is a saggy mess
Loose
Hanging out
No fuel is leaking out past this saggy O ring
But not creating a tight seal, not enough pressure?
Diagram below
The red oval is the saggy O ring
Throttle body fuel injector housing o ring.JPG 44.22K
0 downloads
Could this be all or part of the problem?
Anyone know where I can get a replacement?
Nothing on Mini Spares
Almost all components of the throttle body are no longer available
I'll have to keep an eye open for a second hand spare
For when (not if) I need one
Or is all this a red herring and this is more an indicator that there's no power to the injector(s)?
Fuel being pumped into a small spaces
Injector not injecting (no power)
Fuel being forced around the the injector
Possibly some through it too
But not following the injected route
Engine management relay?
Edited by Elwyn, 04 August 2021 - 08:16 PM.
Posted 06 August 2021 - 09:35 AM
FS
Hello FS
Your question has been going round in my head for a few days now
The end of the crank shaft and the keyway locking plate can only go together in one position / orientation
I suppose it's possible to force the keyway plate on / in 180 degrees out, but that would take some stubborn walloping
BUT, the flywheel can be put back onto the primary gear in one of 29 orientations (the primary gear having 29 teeth) as long as the clutch plate grooves / slots align with the same on the primary gear
Is that right?
If so, simply putting the keyway back in the right orientation is close to meaningless in terms of the flywheel orientation
Is that also right?
If the answers are yes and yes, it's more than likely that I've put the flywheel back on in one of the 28 wrong positions
Is that what you were thinking when you asked the question?
The engine is back in the car, but I can get the wok off and the flywheel out
Is there manual / Haynes page reference to refer to for getting this right?
Find TDC and locate gap(s) in the reluctor ring with the crankshaft sensor?
Presumably a little more to it than that?
Thanks in advance
Elwyn
Edited by Elwyn, 06 August 2021 - 10:08 AM.
Posted 06 August 2021 - 12:49 PM
In the Rover Service repair manual for SPI Minis, totalling 482 pages (which is VERY good), pages 174 - 178 (inclusive, by PDF page number counter) describe the process of removing the wok, the flywheel / clutch etc and for their subsequent re-fitting.
The same manual describes the function of the gaps in the reluctor ring, the crank sensor, TDC and the ECU MEMS with regards to timing.
Where it talks about the reluctor ring / crank sensor / TDC / ECU timing functionality, it refers you to the Clutch section.
In the clutch section (pages 174 - 178), it makes no reference to the reluctor ring / crankshaft / TDS positioning and alignment that's presumably needed.
It basically says, "put it back on and tighten things up"....not quite those words exactly
Does anyone know if it's somewhere else in the 482 pages?
Thanks in advance
Elwyn
Posted 08 August 2021 - 09:52 AM
Posted 11 August 2021 - 10:10 AM
UPDATE
The engine is running
On all 4 cylinders
Still with some fine tuning to do, but it's a huge step forwards
Thanks for all the helpful advice, thoughts, theories and pointers
Regards
Elwyn
Posted 11 August 2021 - 08:29 PM
