Quite shocked at how high mx5nut car looks. I hope they settle down. I purchased a set of these earlier this year but haven't fitted them yet. Disappointed if that is a typical result as I bought these thinking Hilos would not be required as Minispares state on their web page. Indeed the page says if Hilos are used the hysterisis on the cones will be affected. As mx5nut says there is no specific recommendation on the web page to fit Hilos.
Ride Height After Suspension Rebuild
#16
Posted 13 August 2021 - 06:16 PM
#17
Posted 13 August 2021 - 07:24 PM
If I don’t see much more progress in terms of settling over the next week, I may reach out to Minispares.
#18
Posted 14 August 2021 - 08:54 AM
#19
Posted 16 August 2021 - 06:47 AM
Of course the changing ride height may change the wheel alignment, so keep an eye on that too
#20
Posted 16 August 2021 - 07:41 AM
I am sure you have this covered but did you tighten the parts with rubber bushes after lowering to the ground? so as to not "set" them incorrectly.Similarly it may pay to loosen and retighten after settling?.Just a thought,Steve..
#21
Posted 18 August 2021 - 04:42 PM
#22
Posted 24 August 2021 - 01:58 PM
Ok, so going back to my original question about whether or not it is normal for the car to sit high like this right after lowering the car, it seems like the answer is “yes.” For the record, I am totally fine with that and waiting for some period for settling. Since this is my first time doing suspension work in the Mini, I am being cautious and wanting to verify my work. I am also going to move the car around in my driveway and go for some short drives in my neighborhood to help the settling.
Gav mentioned that hi-los were recommended in the recommendation section, but regular trumpets are also in the same section. I wonder if they could clarify the product description to add a statement on ride height expectations for use with regular trumpets and hi-los. Maybe something to say that using regular trumpets is totally fine, but that initial ride height will be well above normal and eventually settle to factory ride height (or something close).
I've added a small amendment to the web description :)
#23
Posted 24 August 2021 - 08:46 PM
Good man, brilliant customer support
