Oil Leak
Posted 07 November 2006 - 08:20 AM
Posted 07 November 2006 - 08:32 AM
hi i hav a oil leak and it seems to coming from the fuel pump area and i was wonderin were exactly were its comin from any suggestion please
prob the gasket between the pump and the block there shuld be a plastic spacer between the pump and the block with a paper gasket either side of it .
easy fix
Posted 07 November 2006 - 08:37 AM
The bit that connects the gear stick to the gearbox.
Or it could be the pump.
Posted 07 November 2006 - 05:58 PM
easy fix
how do i get to it easily espically the left hand bolt
Posted 08 November 2006 - 12:54 AM
Posted 10 November 2006 - 06:43 PM
Posted 10 November 2006 - 06:47 PM
Posted 10 November 2006 - 06:52 PM
Posted 10 November 2006 - 07:02 PM
Posted 11 November 2006 - 07:27 PM
Posted 14 November 2006 - 11:04 AM
Why did you think it was coming through the fuel pump?? If you think logically about it, if you were getting oil in your fuel pump your engine would be running very poorly, since oil would be getting into the mixture, and your sump properly would have exploded by now, because you'd be getting petrol in an area where a lot of metal is meshing and grinding together (the gearbox).:'( right fitted new fuel pump and i still have a leak what else couldit be :'(
Best thing to do when trying to find a leak is to clean the area where the leak is coming from (either a pressure washer, or preferably just some soapy water/Gunk and a hose). Run the engine for a few minutes and see where there is fresh oil.
I suspect either the tappet covers, or the gasket between the engine block and gearbox (I've never had a mini that didn't leak from this area).
Posted 20 November 2006 - 10:02 PM
