Oil Pressure Gauge Install - Fouling Distributor
7 replies to this topic
#1 GeraldTheMini
GeraldTheMini
  • 17 posts
Posted 19 September 2021 - 08:07 PM
Evening all, someone must of had/seen this issue before. I have a metro 1275 engine, 65D distributor with vac advance. Started installing a smiths oil pressure gauge, with tee fitting and adaptor, braided Goodrich hose. Ignition timing is set (to what I think is correct). The vac advance unit is right in front of the oil pressure switch port. Which fouls the tee piece, or the switch. It even fouls when I lose the switch completely and just use the adaptor and braided hose straight into the block. Can't really see a way around it... Any ideas?
#2 GraemeC
GraemeC
  • 7,446 posts
Posted 19 September 2021 - 08:11 PM
Check and record the timing, remove the dizzy and then rotate the dizzy drive spindle one tooth.
Re-install dizzy and set timing as it was.
If that doesn’t provide enough clearance rotate another tooth, or go the other way.
#3 panky
panky
  • 1,792 posts
Posted 20 September 2021 - 01:15 PM
Or move the leads around one position in the dizzy cap then re-time.
I used one of these on my Minor when I had the same issue
https://www.ebay.co....tm/164633078441
It replaces the banjo bolt on the feed to the filter and does away with a T piece. Only suitable for earlier engines before 1990 though.
Edited by panky, 20 September 2021 - 01:18 PM.
#4 Ethel
  • 26,104 posts
Posted 21 September 2021 - 08:41 AM
As above,
You can turn the whole dizzy in 90 degree increments, just move the leads to the next post in the opposite direction.
Only thing with Panky's adapter is you'd be measuring pressure before the filter, I think off the main gallery, as standard would give a more reliable indication your engine's happy.
Still good for temp. sensors & relocating pressure warning switches.
#5 panky
panky
  • 1,792 posts
Posted 21 September 2021 - 10:54 AM
Good point, I suppose you could plumb in two gauges to show the differential pressure across the filter if you really wanted to worry yourself ;D
#6 nicklouse
  • 18,724 posts
Posted 21 September 2021 - 12:01 PM
As above,
Does not need to be 90 degrees.  It can be one tooth or more.
#7 Ethel
  • 26,104 posts
Posted 22 September 2021 - 10:59 AM
If you go for the easier option of just slackening the clamp & turning the dizzy you will need to keep to 90 degree steps - same as the cams that open the points (or electronic equivalent).
#8 kiwi topcat
kiwi topcat
  • 36 posts
Posted 23 September 2021 - 08:08 PM
easy way is to buy a 45 degree angle and nipple screw them into the block and then use the tee for oil and gauge
