Laygear For Tran-X / Minispares 5-Speed Gearbox
3 replies to this topic
#1 MaximMini
MaximMini
  • 226 posts
Posted 10 October 2021 - 10:35 AM
Hi Everyone,
Having tried all sorts of resources I unfortunately wasn't able to find a suitable replacement laygear for my 5-speed gearbox. What I'm looking for is basically any laygear with the splined bore to except (drive) the layshaft for the fifth gear.
The gearbox I'm owning is a very early one and has what is a DAM3169 but with different machining, but I would take what ever I can get hold of even if I would have to change the corresponding gears.
Thank you very much for any hint in the right direction.
Christian
#2 whistler
whistler
  • 1,895 posts
Posted 11 October 2021 - 09:16 AM
Try contacting John Guess to see if he can help.
http://classicminige...Tech/engine.htm
#3 MaximMini
MaximMini
  • 226 posts
Posted 11 October 2021 - 01:53 PM
Have talked to John already. Thanks
#4 semag
semag
  • 54 posts
  • Local Club: Newport Mini Owners Club
Posted 14 October 2021 - 11:19 AM
I had this problem a few years ago; when I inspected the original lay gear I found that the spline was actually an insert that had been fitted to a bored out standard lay gear and then welded in place. I got the weld machined away by cutting a `V` groove and then drove the insert out. Then bored out a standard lay gear to suit and pressed in the insert. I didn`t weld it at that point but drilled and tapped holes half and half and fitted grub screws to retain it.
Hope this helps
