What Cca Battery
20 replies to this topic
#1 IronmanG
IronmanG
  • 1,236 posts
  • Local Club: Box hill. Lsmoc member
Posted 02 November 2021 - 07:21 PM
What cca battery are you running in your mini. Mine is 330cca and is really struggling to turn it over.
#2 Cooperman
  • 23,294 posts
Posted 02 November 2021 - 08:00 PM
Mine are both 510 CCA and work fine even with the 11:1 cr on the S.
#3 IronmanG
IronmanG
  • 1,236 posts
Posted 02 November 2021 - 08:08 PM
Cheers. Ye we had to put a booster pack on it to get it to crank.
If everyone is using 400 or so plus then that would seem the obvious problem. Earthing seems ok
#4 timmy850
timmy850
  • 3,340 posts
  • Local Club: MITG
Posted 03 November 2021 - 01:38 AM
My old one was 260CCA and it worked fine
I swapped to a bigger 560CCA battery when the first one died, mainly as it filled up the battery box a bit better
#5 cal844
cal844
  • 9,624 posts
  • Local Club: TFMOC
Posted 03 November 2021 - 09:45 AM
I use a Yuasa 063 size battery with 425CCA, it'll crank my 998 or 1275 into life even after 3 months of hibernation
#6 beardylondon
beardylondon
  • 1,551 posts
Posted 03 November 2021 - 10:08 AM
Use the same 063 size, many many years ago I was told it was the best fit for the size hole and was apparently the same as the metro, could be wrong!
#7 GraemeC
GraemeC
  • 7,438 posts
Posted 03 November 2021 - 10:18 AM
So many factors will affect this - temperature, cc, compression ratio, cam, condition of solenoid, condition of cables and connections........
330cca should turn even a tuned engine over just fine, so I suspect the problem is elsewhere, either failing battery or poor connections.
#8 IronmanG
IronmanG
  • 1,236 posts
Posted 03 November 2021 - 10:40 AM
I was surprised. Its a new battery and been kept on the charger
Compression 10.1
Everything else is new. I will try a second earth strap possibly and clean the connections again
#9 floormanager
floormanager
  • 698 posts
  • Local Club: Mini Club Sussex
Posted 03 November 2021 - 08:13 PM
Don't discount a dodgy starter.  I had one of them, would barely crank.  Changed it and it flew around
#10 IronmanG
IronmanG
  • 1,236 posts
Posted 03 November 2021 - 08:41 PM
Ye we took it off and connected a battery across it. Spun up ok but that's not to say its spot on. Can try new brushes give it a clean firat
#11 IronmanG
IronmanG
  • 1,236 posts
Posted 04 November 2021 - 11:59 AM
I've tested from the battery to various points on the engine and body and I'm getting 0.3 ohms resistance. Its consistent between both so that rules out earthing unless anyone thinks that's a bit high?
#12 GraemeC
GraemeC
  • 7,438 posts
Posted 04 November 2021 - 12:22 PM
Doesn't really mean anything as poor connections can show low resistance, but then break down under load.
Likewise a starter spinning on the bench doesn't mean it won't be lazy once you ask it to do some work.
#13 KTS
KTS
  • 2,437 posts
Posted 04 November 2021 - 01:14 PM
..what voltage are you seeing on the starter terminal when cranking, and how does that compare to the voltage on the battery post when cranking.
losses in the connection between battery and starter will show as a voltage drop between the two when under load
#14 IronmanG
IronmanG
  • 1,236 posts
Posted 04 November 2021 - 05:05 PM
Will check that Pat, cheers
#15 floormanager
floormanager
  • 698 posts
Posted 04 November 2021 - 07:31 PM
Same with mine,  New brushes, bushes, new bendix but would take high current and barely turn the engine.  Changed the starter - spun over like a nutter!
