Thermostat Bolt Removal
21 replies to this topic
#16 nicklouse
  • 18,657 posts
Posted 19 November 2021 - 06:41 PM
Have a watch for those that want to know how to deal with stuck and broken studs in cast iron.
https://youtu.be/khQEC38X_mA
#17 Tornado99
Tornado99
  • 750 posts
Posted 19 November 2021 - 07:22 PM
This is a good method when there is enough stud remaining outside the hole to weld to or get  mole-grips on. When the stud/bolt breaks off nearly flush with the surface or even down in the hole, other methods need to be employed such as drilling a pilot hole to fit an Easy-Out extractor or similar bit. Fully drilling out the stud's core, then chasing with a tap is also possible.
#18 sonscar
sonscar
  • 3,031 posts
Posted 20 November 2021 - 11:49 AM
Easy out?I find them as snap off in the hole outs.Not my first or perhaps ever choice.You may of course be less ham fisted,Steve..
#19 bpirie1000
bpirie1000
  • Area Managers
  • 2,366 posts
  • Local Club: Amoc
Posted 21 November 2021 - 10:16 AM
With heads becoming difficult to find i would get someone who has expertise to do this.
Quite easily ruin a head, causing you a HEAD ache.........(oh dear)
#20 Stu1961
Stu1961
  • 634 posts
  • Local Club: Still Looking
Posted 21 November 2021 - 06:23 PM
Could have them spark eroded
#21 panky
panky
  • 1,792 posts
Posted 22 November 2021 - 11:07 AM
In the past, if snapped off flush, I've used a mig to blob weld on the end of a broken stud and build it up enough to bash an old socket onto it, usually comes right out.
#22 stoneface
stoneface
  • 392 posts
Posted 22 November 2021 - 11:48 AM
Another good way to heat up flush broken studs it using a tig welder, if you have one.
Great for applying heat to a very local area. You don't have to melt the metal and if you have a foot pedal you can control the amount of heat input very precisely.
I use this method for removing oil gallery threaded plugs. You can apply the heat down the bottom of the hex socket without damaging it and then wind it our with an allen key.
