I've just removed an old conservatory, the join between it and the house brickwork was silicone. The bricks are quite textured therefore I cant use an abrasive disc to remove the silicone. I seem to remember seeing a product which dissolved silicone but I've done a search and can't come up with anything. Any thoughts or suggestions would help, preferably from first hand experience.
Silicone Remover
Posted 25 November 2021 - 03:32 PM
Posted 25 November 2021 - 04:22 PM
There are silicone removes made by the usual suspects, but they're generally aimed at getting the sealant out from around baths, sinks etc. so only come in small amounts (and I don't know how good they are):
https://www.screwfix...ver-100ml/88987
https://www.amazon.c...B006FTEU10?th=1
I think for removing it from brickwork you may need to resort to wire brushes, either by hand or drill/grinder mounted?
Edited by GraemeC, 25 November 2021 - 04:23 PM.
Posted 25 November 2021 - 04:47 PM
only a thought, but could it be burnt off with a blowtorch ? (..without making even more mess..)
Posted 25 November 2021 - 06:19 PM
Try to find a rotary abrasive "brush" for a drill. These have abrasive coated brush strands that are great for stripping paint and rust off surfaces. Should help with a brick surface.
Posted 25 November 2021 - 08:50 PM
Posted 25 November 2021 - 09:16 PM
The blow lamp sounds interesting as does the petrol idea so I'll give them a go, if they don't work individually perhaps I'll try them together!
Posted 25 November 2021 - 09:34 PM
Posted 25 November 2021 - 09:51 PM
Posted 25 November 2021 - 11:14 PM
It looks good, I've now got to find a UK equivalent.Found this product...seems to be what you want:
https://youtu.be/8udYLsG2wzg
Posted 26 November 2021 - 10:56 AM
