What Ignition System
9 replies to this topic
#1 A1111j
A1111j
  • 77 posts
Posted 21 December 2021 - 08:25 PM
Hi
what do you guys recommend for a turbo nodiz or megajolt?
Iv have bought a swiftune electronic unit 59D that I am guessing is no good for a turbo build?
#2 Ethel
  • 26,042 posts
Posted 22 December 2021 - 11:59 AM
The Metty Turbo had an electronic 59, but so did the bog standard 1300 Maestro. Dizzies can be modified to limit the maximum advance, but a programmable system with a MAP sensor will be superior. A lot easier to achieve now with COP & coilpacks with built in amplifiers- see Sparkduino
#3 Icey
Icey
  • 1,552 posts
Posted 22 December 2021 - 11:48 PM
I have a megajolt but it’s an old platform now. That’s good because it’s well understood with lots of example maps, but bad as it lacks features newer systems have (mostly a lack of inputs/outputs, CAN etc..).
Nodiz is newer, has more features than megajolt but lacks the community understanding. It also has some weird history that left me a little cold to the product.
If I was starting our project now I’d likely look at Speeduino. It seems to be a well supported product and even if you only start with ignition-only, it leaves you with the option to fit injection later on. Caveat - I’ve not used it, only watched videos and read about it.
Edited by Icey, 22 December 2021 - 11:49 PM.
#4 nicklouse
  • 18,679 posts
Posted 22 December 2021 - 11:59 PM
TBF I would go and talk to the guys that will be setting it up on the rollers. Some will not touch some set ups.
#5 A1111j
A1111j
  • 77 posts
Posted 23 December 2021 - 09:56 PM
Yeh thats why I asked about nodiz as I don't want to get a system that some places cannot tune.
#6 IronmanG
IronmanG
  • 1,253 posts
  • Local Club: Box hill. Lsmoc member
Posted 23 December 2021 - 11:32 PM
Where are you based. Talk to you most local dyno see what they like then see what guys on here think of it?
#7 A1111j
A1111j
  • 77 posts
Posted 23 December 2021 - 11:34 PM
I am in West london.
#8 nicklouse
  • 18,679 posts
Posted 23 December 2021 - 11:37 PM
Find a rolling road and go and talk to them. Unless you feel happy using the pc to set it up.
#9 Ethel
  • 26,042 posts
Posted 24 December 2021 - 12:51 AM
Beats me why any operator wouldn't be happy to tell you how much advance to add where & let you tap it in if you turned up with your own laptop.
A lambda gauge is a worthwhile investment anyway, but with an accelerometer app on your phone and safe stretch of tarmac you could achieve much of what a rolling road does.
#10 A1111j
A1111j
  • 77 posts
Posted 26 December 2021 - 01:28 AM
Yeh I am definitely fitting a wide band. I have checked veemaxscart 15min away from me or I can go to Pete baldwin.
