Heater Resistor Pack - Possible Replacement?
4 replies to this topic
#1 KobukKobuk
KobukKobuk
  • 70 posts
  • Local Club: Mighty mini
Posted 27 December 2021 - 01:28 AM
My spi mini's heater pack resistor broke while cleaning.
The same one is on sale at Mini Spares, but the price is too high.
I did some temporary soldering but no ceramic covering over the coil.
Is there any way to apply something similar to heater pack resistor but relatively cheap?
Thank you for your help.
#2 Ethel
  • 26,022 posts
Posted 27 December 2021 - 02:49 PM
I think you could press one off any car in to service, or you could look for a 12v motor speed controller that uses PWM.
https://www.ebay.co....P0AAOSwZ9hg7SKb
#3 brivinci
brivinci
  • 1,195 posts
Posted 10 January 2022 - 06:20 PM
Did your SPi come with a dual speed heater or did someone add that? I thought only MPi cars had the 2-speeds fitted as standard.
#4 Ado1379
Ado1379
  • 588 posts
Posted 27 January 2022 - 09:12 PM
https://www.ebay.co....0-127635-2958-0
I had the same problem. Couldn’t track a replacement down so I found this instead. I de-soldered what was left of the old resistor coil and soldered this resister to the 2 terminals that were left via via 2 wires. Then drilled 2 small holes on the heater casing and mount the resistor to the inside of the casing keeping it in the air flow of the fan to keep it cool. This way it keep all the original wiring and plugs.
#5 Ado1379
Ado1379
  • 588 posts
Posted 27 January 2022 - 09:16 PM
http://www.minispare.../JGM100100.aspx
Just found this, I guess in this case you are paying for the originality
