A Cursed Car
14 replies to this topic
#1 IronmanG
IronmanG
  • 1,363 posts
  • Local Club: Box hill. Lsmoc member
Posted 10 January 2022 - 11:21 AM
I am not superstitious but I swear to god if something can go wrong it will with this car.
Taken my spanking new 10 x 6 revolutions and yokodramas to a specialist local wheel place to fit and balance.
They've damaged 1 wheel and tyre and said they can't fit them. They have the same problem with caterhams who are based around the corner.
They are replacing both damaged items which is great so I promised them any work down the line for my vehicles I will take them there so he can make his money back but who do I use?
They can't be that unusual surely in the day of 30 profile tyres
#2 GraemeC
GraemeC
  • 7,476 posts
Posted 10 January 2022 - 11:32 AM
I suspect their machine can't handle 10" rims (many can't) and they've tried to fit the tyres manually.
You need to find a garage that still uses an older machine - generally a more old school back street spot.  The same ones that would turn you away if you turned up with 21" rims as their machine won't go that big!
#3 IronmanG
IronmanG
  • 1,363 posts
Posted 10 January 2022 - 11:58 AM
Ye sounds about right
#4 greenwheels
greenwheels
  • 691 posts
  • Local Club: Mini Fixers
Posted 10 January 2022 - 01:08 PM
Similar thing happened to me.
Do they realise Mini wheels have to have tyres put on with the wheels upside down to what they are used to? i.e. the well in the wheel is not in the middle of the wheel but nearer to the outside, so the tyre must be mounted from the outside. Difficult to explain, but try looking at the wheel and remember that as the tyre is mounted it must be pulled down into the well so the opposite side will reach over the rim.
#5 imack
imack
  • 2,382 posts
Posted 10 January 2022 - 01:34 PM
Our wheel balancer at work can't even mount 10" wheels!
Edited by imack, 10 January 2022 - 01:35 PM.
#6 IronmanG
IronmanG
  • 1,363 posts
Posted 10 January 2022 - 02:54 PM
Not sure. He just said yokohams are always difficult. The effort has just cost him nearly 150 quid though
#7 stoneface
stoneface
  • 439 posts
Posted 10 January 2022 - 03:53 PM
The last place I had my 10" wheels done and also 10" wheels fully aligned was "Topmarks Tyres" in Coulsdon
A bit further from Crawley but might be worth a call to check.
#8 Midas Mk1
Midas Mk1
  • 5,854 posts
  • Local Club: S.U.N.M.C
Posted 10 January 2022 - 07:09 PM
When I fit 10" tyres do them with the wheel upside down, there were 10x6 mws wheels (revolites) 10-15 years ago that had the wrong profile well and wouldnt remove without damage.
#9 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 11 January 2022 - 02:21 AM
Probably a bit far away for you Graham but before i moved i used JP Tyres in Eastbourne. They fitted my Yokos to my Cooper S rims with no problams.
#10 coopertaz
coopertaz
  • 950 posts
  • Local Club: a-series-magpies
Posted 11 January 2022 - 11:02 AM
same problem with other halfs due to large offset, as stated have to be fitted from rear with wheel upside down then wrestled while inflating to seat bead, had a friend finally do hers after garage knackered one tire
#11 IronmanG
IronmanG
  • 1,363 posts
Posted 12 January 2022 - 09:45 AM
The new wheel and tyre are in so I will be picking these up today.
I asked about fitting and he said they tried upside down they just aren't going
#12 OzOAP
OzOAP
  • 402 posts
Posted 12 January 2022 - 10:30 AM
Try Horley Tyre and Exhaust.
#13 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 12 January 2022 - 10:52 AM
 Not sure I'd agree with the Yoko comment - I've never had any Yoko's fitted professionally for years, always done them myself with tyre levers and they go on fine.
At least he's offered to help, £150 is a lot of profit when you take all his costs out.
#14 SolarB
SolarB
  • 1,406 posts
Posted 12 January 2022 - 11:23 AM
Yep, sounds like cursed to me. I've had a fair number of A008 and A032 tyres successfully put on 10" wheels at 3 different garages.
The only slight problem I have ever had is that balance weights on the inside have to be carefully positioned if they are not going to catch on the front calipers.
#15 IronmanG
IronmanG
  • 1,363 posts
Posted 17 January 2022 - 03:55 PM
Tried 6 garages. 2 broken tyres. 1 broken wheel and another thats marked and the guy won't take responsibility.
All these race minis that have 10 inch wheels. Where do they go
