Bimetallic Strip
11 replies to this topic
#1 maystro
maystro
  • 298 posts
Posted 16 January 2022 - 10:14 AM
Hi Guys,
My new recond mini engine over heated because of a radiator fail.  It got hot but only hit 95 Celsius for about 10 seconds before I shut it down.   When I restarted the motor it had a slight miss under acceleration.   I put in a new radiator, and inlet/exhaust manifold gasket thinking it was sucking in air making it run lean. Oh yeah I did a compression test and I am getting 185-190 psi so no head gasket problems.
I noticed when it is breaking down, if I pull the choke on it runs perfectly.
So I changed out the BBW needle to a BDK needle and my motor has never run better.  Not a miss and it seems to run cooler now that the plugs are not white which were they with the BBW.
I was originally running this BDK needle before I took my car for a rolling road and they swapped it out for the BBW saying it was too rich at the lower/mid range, the plugs were always a lot whiter than I liked though after they changed them.
My question is could I have damaged the Bimetallic strip in my new HIF44 carby when my motor over heated so that now I need a richer needle to compensate?  Can this strip be permanently damaged by excessive heat?
Thanks Brad
#2 PoolGuy
PoolGuy
  • 867 posts
Posted 16 January 2022 - 10:31 AM
I very much doubt that you’d damage the temperature compensator with heat, taking into account where it is.
#3 whistler
whistler
  • 1,837 posts
Posted 16 January 2022 - 11:41 AM
Check that the vacuum advance/retard plastic pipe hasn't a burn hole in it.
#4 nicklouse
  • 18,751 posts
Posted 16 January 2022 - 02:30 PM
Very unlikely you have damage anything in the carb by getting the engine up to only 95c
#5 Ethel
  • 26,159 posts
Posted 16 January 2022 - 04:22 PM
Expect you'd have to boil the float chamber dry to do that. If it was down to the strip, more likely it was over compensating on the rolling road, but a sticky float valve/pivot or gummed up jet are more likely, I'd say - or they just misinterpreted where the needle lift was at.
#6 maystro
maystro
  • 298 posts
Posted 17 January 2022 - 09:28 AM
Ok thanks Guy's,
I shouldn't be complaining because my engine is running sweet since I changed the needle from a BBW to a BDk .  I was just worried I damaged something in the new HIF44?  Not to many guys in my area run HIf44's, they run the HS4's or HS6's?
Brad
#7 Ethel
  • 26,159 posts
Posted 17 January 2022 - 12:14 PM
Making up a solid replacement was a thing with turbo enthusiasts.
There's also this, but it doesn't sound like you need it & there's the bulkhead clearance thing anyway. AFR Gauge is the jobby if you really want to get in to carb tinkering.
#8 GraemeC
GraemeC
  • 7,451 posts
Posted 17 January 2022 - 02:30 PM
Those HIF float extensions have got to be one of the most pointless things going!
#9 croc7
croc7
  • 821 posts
Posted 20 January 2022 - 07:08 AM
Ok thanks Guy's,
Brad
I removed the bi-metallic strips from the temp compensator-10 minutes with a Dremel and a steady hand is all it takes. I did so to defeat the compensator changing the needle position in the jet while trying to adjust the Air/Fuel ratio. Seemed to have worked but to be honest, with the camshaft I have, getting a steady AFR reading has always been kind of a hit/miss.
But if the engine is running well and you’re happy-live well and prosper.
Edited by croc7, 20 January 2022 - 07:09 AM.
#10 oliver122
oliver122
  • 1,007 posts
Posted 28 September 2023 - 08:44 PM
Ok thanks Guy's,
Brad
Have you got any pictures of this mate as I'm thinking of doing the same
#11 croc7
croc7
  • 821 posts
Posted 29 September 2023 - 09:58 PM
Ok thanks Guy's,
Brad
Sorry, no pictures but once you have removed the compensator, you will see how easy it is.  Do a search, I seem to recall instructions w/ pictures from a fella in Australia or maybe one of those on the turbocharged forum.
#12 timmy850
timmy850
  • 3,413 posts
  • Local Club: MITG
Posted 30 September 2023 - 09:11 AM
There’s some photos here
https://www.theminif...ic-strip/page-2
