Cam Choice, 998 Engine + Twin 1+1/4" Su's
Best Answer stuart bowes , 26 January 2022 - 01:49 PM
Thanks again for the suggestions, I got a reply from Kent cams as well they say they recommend the MD246 for good torque from 2000 and revs to 5.6/6
I guess the decision will be made partly on cost, anything up to and around £200 is pretty feasible, more than that is probably excessive..
Thanks for additional pointers on the exhaust as well but for now as I said just to get the lump back in the cam will be job no 1 and as long as everything else looks OK I'll probably leave the bottom end alone, it's not high mileage or showing any signs of bore damage which is all I've really looked at so far Go to the full post
23 replies to this topic
#16 stuart bowes
stuart bowes
  • 2,248 posts
Posted 27 January 2022 - 12:07 PM
good suggestion thanks
in that case though, why not get the 202 for now which is about £60, forget the valve seat work which was the main part of the cost, get a skim (£45) and run it with additive
for now.  not long term for best perfomance, etc
Edited by stuart bowes, 27 January 2022 - 12:53 PM.
#17 stuart bowes
stuart bowes
  • 2,248 posts
Posted 27 January 2022 - 12:55 PM
in fact that is what i've done, £60 is an easy gamble to be fair
at least it's got bigger inlet valves and I'll measure it to work out if skimmed already or how much to have skimmed
better than standard, anyway
#18 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 27 January 2022 - 01:02 PM
The 202 in standard form can barely be considered an upgrade. You’re looking at a couple of hp gain.
With some work they can be made decent. They also have larger chambers than the stock 998 head, so without a skim to correct the volume your compression would be lower.
The standard head can be modified to give good results, but requires bigger valves and a lot of port work to be effective.
Phil.
#19 stuart bowes
stuart bowes
  • 2,248 posts
Posted 27 January 2022 - 01:07 PM
well exactly, so I get the 202, skim it as mentioned aready, it already has bigger valves, so it's an improvement on the standard head.   later on I can pop it off again, get it worked a bit and sort valve seats for unleaded
plus the replaced cams, and per the main point of this thread..  seems like a decent plan to me..
maybe I can get an expensive head later but it doesn't seem necessary for now, I just want to improve the carbs chances slightly for now
I'll probably smooth out the bores a bit myself if needed, that's pretty straight forward stuff
Edited by stuart bowes, 27 January 2022 - 01:22 PM.
#20 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 27 January 2022 - 01:55 PM
Yes the 202 has a bigger inlet valve (the exhaust is the same as all other small bore heads) but due to the heavily shrouded chamber shape you don’t see the full flow potential of the bigger valve, hence the minimal gain in hp. Some chamber reshaping yields some decent results.
Phil.
#21 stuart bowes
stuart bowes
  • 2,248 posts
Posted 27 January 2022 - 02:53 PM
presumably also the skimming will reduce the effect of that shrouding? at least a reduction in depth
thanks for the additional info I will certainly bear it in mind
Edited by stuart bowes, 27 January 2022 - 02:54 PM.
#22 sonscar
sonscar
  • 3,047 posts
Posted 27 January 2022 - 03:15 PM
Save up and get it all done together would be my choice.I understand this is not always possible.Steve..
#23 stuart bowes
stuart bowes
  • 2,248 posts
Posted 27 January 2022 - 03:29 PM
it's not so much the availability of the money it's more a case of doing it in stages to make sure that each step is 'worth' doing if that makes sense
like right now we're still doing body work and the engine is kind of a side issue, but I'm getting a few bits in and covering a few bases to make sure some bits are on the shelf ready to go
obviously I can't skim it myself, but I can do some work with the dremel to open out the chambers and smooth out the ports and see where that gets us
#24 stuart bowes
stuart bowes
  • 2,248 posts
Posted 27 January 2022 - 04:19 PM
interesting info here on this topic
http://www.guy-croft...topic.php?t=532
and signing this thread off now because it's wandered off topic
thanks all
