Coming along sterling fashion, matey!!
1988 Mayfair Rebuild (998)
#421
Posted 09 June 2025 - 03:19 PM
#422
Posted 11 October 2025 - 03:51 PM
well it ended up being a bit more than 2 months due to various daily life occurrences but finally got the floor and bulkhead areas prepped for paint
not much to add beyond here are pics of it happening, all pretty straight forward just really time consuming
I was focusing mostly on seams and joins for obvious reasons, nothing untoward found (I did actually strip all paint everywhere despite what the pics show, there would have been 10x more pics otherwise and that just seemed unnecessary)
stripped, kurusted just for the hell of it, seam-sealed and red-oxide primed:
Edited by stuart bowes, 10 November 2025 - 05:50 PM.
#423
Posted 11 October 2025 - 04:01 PM
also, I have got around to the engine strip down and have just started the long process of getting the parts cleaned up and inspected, bolts all labelled and bagged up, etc
flywheel put up a fight with a cheaper flywheel tool, so that got binned and replaced by the Draper one, which does work (https://www.minispar...-mini-act19862/)
Edited by stuart bowes, 11 October 2025 - 06:48 PM.
#424
Posted 12 October 2025 - 06:24 AM
Hi Stuart,
Being my suggestion I am pleased to see that the Draper puller worked.
I have never had any major problems using it.
Paddy
#425
Posted 12 October 2025 - 10:48 AM
#426
Posted 12 October 2025 - 12:30 PM
Looking good Stu, always feels good to see a a repaired section receiving a uniform layer of paint afterwards! Looking forward to the engine refresh
#427
Posted 18 October 2025 - 09:41 PM
Sorting out the rear seat base, had to get all that sound deadening off first of course, gave all the seams a good wire-brushing out as usual, kurust for luck, new seam sealer and primer
kicking myself a bit now having just realised there's 4 more bung plugs in the seat base and I can't now weld them up having the underside already done and painted (not to mention rear subframe in way of the front two). Will just have to replace the bungs with a decent bit of sealant I guess
Eagle eyed viewers may notice I've wedged some newspaper between subframe and holes as a bit of protection
Edited by stuart bowes, 25 October 2025 - 10:14 AM.
#430
Posted 23 November 2025 - 08:13 PM
roof sorted, zero rust not even surface spots.. lots of sticky gunk from where they glued on the felt stuff, a bit of a rub down with acetone took the worst off, not over concerned with that, just painted over whatever was left
Edited by stuart bowes, 24 November 2025 - 12:38 PM.
#431
Posted 16 December 2025 - 12:19 AM
have been working on the doors, firstly make sure the modifications that I've done on the driver side are the same on the passenger side (slightly enlarged access holes and a pivot point for the lock actuator)
now that's all done I can strip all to bare metal, and for the inner carcasses I am still sticking with the red oxide. the outer door skin and the visible parts of the window frame will be prepped and painted in the normal 'paint job' way but the insides are irrelevant obviously anyway and most of the rest has a door card over it (it'll still get a good rub down as smooth as I can but I won't be losing sleep over it)
anyway some pics of that happening:
Edited by stuart bowes, 15 April 2026 - 03:31 PM.
#432
Posted 17 September 2026 - 06:26 PM
woohoo finally another update .. I have actually been doing a few bits here and there but I'm just collecting pictures as I go so I can do updates in batches to see each thing start to finish rather than going back and forth on stuff
I was painting the inside floor wherever sound deadening and carpet is going, that's all just black because why not, I had a tin to hand and no-ones ever going to see it, sue me.. but I stopped when I remembered I hadn't sorted out the rear/lower front subframe mounts yet, so that's what this update is about
because this is all solid mount and there's the well-known issue of damage to the lower bulkhead I basically copied what I saw on someone elses project (apologies, can't remember who now!)
took off the mounts, measured up, ordered some 3mm plate, cut to size:
also put some under the bolt head / nut in the floor, trying to stop any water getting in that way as well
I'll cut the sound deadening around the bolt heads and with the carpet over the top I'm pretty sure there won't be any noticeable 'lumps'
new bolts added are all 5/16" UNF in keeping with other existing bolts to subframe, figured I might as well stay imperial and make sure they're not some confusing mixture of nuts and bolts. also took opportunity to change the nuts to nylok which isn't what was supplied in the kit originally, a bit of peace of mind none of it will jiggle free (still got to change the ones you can see which aren't done yet.. they're on order)
not really sure if any of this will make much difference strength-wise, but it can't hurt anyway, has to be at least slightly better than standard, and I didn't want to get into welding massive plates inside. It's not going racing or anything anyway, just general road use
now I can get on with finishing the black paint inside, that'll be the next update
Edited by stuart bowes, 18 September 2026 - 08:45 AM.
#433
Posted Today, 11:31 AM
That's a brilliant job, Stuart. Thanks for taking the time to add the detail and photos. You have really engineered a great bracket to improve on the original. It is just the sort of thing my mate would do, but is probably more belt and braces than I need to do at the moment.
The main reason being the floors on mine are nowhere near as decent as yours, so that bottom folded brace would be largley ineffective. The problem with mine is largely due to the fact that the previous idiot owner tried to fit a pre 76 subframe, so just literally drilled the holes in the floor, which were quite close, but also whopping holes in the bulkhead to fit the two mounting bolts on each side. The first stage has been to fill those holes with washers and a skim of filler to make good. Then to tackle the floor, albeit it in a temporary manner. We are hoping to move house, so the car needs to be drivable.
