Seen these around, have worked out the rear, but how do the front ones fit??? seen the pics in the archives but hey none the wiser.
Bull Bars Nudge Bars
splintercat
, Feb 11 2022 07:25 PM
3 replies to this topic
Posted 11 February 2022 - 07:25 PM
Posted 11 February 2022 - 10:57 PM
There are two brackets that snake under the bonnet and bolt onto the slam panel and the main supports go through the two holes in the front panel for the front subframe mounting bolts.
One type has a nut welded into the nudge bar in which case you remove the standard subframe mounting bolt and replace it pointing outwards to bolt into the bar instead of a nut.
The type other has the end of the nudge bar tubes flattened with a bolt hole in it. These are designed to sit along side the later towing eyes and are held together with a penny washer and bolt through the towing eye and nudge bar on each side.
Posted 12 February 2022 - 01:52 PM
thanks,,,,,,you must be the only person alive that knows how to fit these? thank youi
Posted 12 February 2022 - 03:05 PM
Mini fitted to the towing eye replacement bolts for the front subframe.
but they are not all the same fitting originally it depended on who made them back then.
