Poor Running - Classic Mini
24 replies to this topic
#16 Marc13
Marc13
  • 216 posts
Posted 04 March 2022 - 09:06 PM
Also, are you sure your ignition is ok? Good leads? Clean distributor cap on the inside? Good ignition timing settings?
If you cant check the last, army least check if the distributor is not lose and can't be turned around by hand
Im sure ignition is ok,but i will double check the obvious.
If ignition was a problem (if) - would this explain why awful when cold, but fine when warm?
#17 Marc13
Marc13
  • 216 posts
Posted 04 March 2022 - 09:07 PM
Your carb dashpot would have used 20w50 engine oil from the factory. Its what I've used on all my minis and I've never had an issue.
So i should drain the dash pot of the su oil and replace with 20W50 engine oil? Do you know how many ml to put in?
#18 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 04 March 2022 - 09:21 PM
You can try, I use the cap of the container your oil is in, half a cap should be sufficient
Having said that you'll struggle to measure half a cap, if it overfill don't worry about it
Edited by cal844, 04 March 2022 - 09:22 PM.
#19 D 'n A
D 'n A
  • 99 posts
Posted 05 March 2022 - 08:24 AM
If the problem is that the engine bugs down on sudden full throttle then the dashpod oil would be the first suspect. Fill it until its nearly full and do a test drive. If you currently have SU oil you should notice a difference.
If there is still no difference I would think the vacume advance on the ignition may be the issue.
#20 D 'n A
D 'n A
  • 99 posts
Posted 05 March 2022 - 08:28 AM
When you take off the dashpod to drain it, you can see the hole the needle falls into. Pull the choke and see if the brass colored pipe changed position. When you use the CO adjuster you should also see it move
Also on the top of the needle there is a 3 letter code. You can now read it with the dashpod out
#21 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 05 March 2022 - 08:37 AM
To read the needle code means unscrewing the needle from the piston, it's easy just be cautious of the small spring and collar
#22 sonscar
sonscar
  • 3,000 posts
Posted 05 March 2022 - 10:02 AM
The dashpot does not need filling,indeed this can cause the engine to smoke.Look carefully and you can see the top of the piston hollow rod.This needs filling almost to the top.This may be an inch or so below the threads.Steve.
#23 Marc13
Marc13
  • 216 posts
Posted 06 March 2022 - 12:03 PM
To add a point, but not having had a mini before , I have nothing to compare it to. When the bonnet is raised and you blip the throttle from the engine bay, you can hear the air being sucked in at the K&N filter, at the same time, the engine fades away. The more throttle you give it, the more it wants to dies. Then when its had a run its ok.
#24 Marc13
Marc13
  • 216 posts
Posted 06 March 2022 - 01:09 PM
Think I've more or less solved it. Adjusted the choke cable slightly and now using full choke on start up and I'm 95% happy with it. Hard press of the accelerator and it builds the revs.
Because it starts every time without any choke, I was only giving it a little bit of choke and the problem was there every time. Now with full choke, its fine.
Think I might still change the dash pot oil to the 20W50 though.
#25 Alex_B
Alex_B
  • 4,573 posts
Posted 06 March 2022 - 05:25 PM
When adjusting your choke keep in mind pulling the choke cable achieves two things. The first part of the travel operates a little cam adjuster which opens the throttle blade to raise the idle, then pulling further should then pull down the jet which pools a little more fuel in the carburettor which enrichens the mixture. So you may have found it was just cracking the throttle open before which would explain the bogging from it running lean when cold.
