High Co And Idle (Mot Failure)
Best Answer RWD3M , 24 February 2022 - 04:03 PM
FWIW, I got to the bottom of this yesterday after fitting new water temp and ambient air temp sensors. The idle control valve was all gunged up. So a good clean and normal service has been resumed.
Thanks to those that offered advice.
Richard.
Go to the full post
4 replies to this topic
#1 RWD3M
RWD3M
  • 57 posts
Posted 21 February 2022 - 05:15 PM
Hi all,
In preparation for the approaching spring (asuming we get one this year) I took my wife's '97 MPi for an MoT this morning. Unfortunately, it failed on emissions, specifically high CO (HC and Lambda both ok). Additionally, the idle seems a little (a lot?) on the high side at around 12 - 1400 rpm. Following lengthy research here, I've checked that all the vacuum hoses are ok so I'm inclined to believe that I may have an issue with the water temperature sensor.
For the want of £15, I've ordered up a new temperature sensor (and gasket) which I'll pick up and fit tomorrow, but just wanted to know if you think I'm barking up the right tree?
Many thanks,
Richard.
#2 bpirie1000
bpirie1000
  • Area Managers
  • 2,346 posts
  • Local Club: Amoc
Posted 21 February 2022 - 06:05 PM
How long has the car been sitting? I would also suggestthat it may need a longer drive to the mot test station. Keep the revs high and get the cat all hot and burn off the carbo built up.
I would also think about testing the tollerances of the lambda sensors.
#3 RWD3M
RWD3M
  • 57 posts
Posted 21 February 2022 - 06:18 PM
Hi, and thanks for the reply.
It hasn't been sitting long, however!!! it has only done about a hundred miles since the last MoT (yes, I know, shameful).
The run to the MoT station is about 15 minutes along pretty deserted roads so I am able to apply the Italian tune-up!
I am interested in the Lambda sensor testing, can you tell me more?
Richard.
#4 bpirie1000
bpirie1000
  • Area Managers
  • 2,346 posts
  • Local Club: Amoc
Posted 21 February 2022 - 07:21 PM
have a look at this..
https://youtu.be/Fl3aD1qJrEg
#5 RWD3M
RWD3M
  • 57 posts
Posted 24 February 2022 - 04:03 PM   Best Answer
Richard.
