Dam5626 Casing, Things To Look For?
18 replies to this topic
#1 ac427
ac427
  • 679 posts
Posted 02 March 2022 - 07:42 PM
I am thinking of getting a secondhand gearbox to rebuild. I would like to know what to look out for when buying a secondhand gearbox, especially the A+ DAM5626.
What exactly do you have to check for on the centre web, is it just cracking and that the hole is not tapped?
#2 MaximMini
MaximMini
  • 226 posts
Posted 03 March 2022 - 07:06 AM
Hi ac427,
With regards to the centre web the DAM5626 is the strongest one as there are only three threaded holes bored to keep the main bearing retainer. One damage I came by in the past you can see in this thread:
https://www.theminif...-housing-scrap/
But then you will only be able to see after dismantling and clean.
As a precaution I do grind the centre webs smooth to avoid any stress risers on my gearboxes.
#3 Spider
  • 14,984 posts
Posted 03 March 2022 - 08:09 AM
Find an early one. I know those up to 1988 were pretty good. They maybe a few years after that too, but I haven't yet come across them to check. The late ones, from about 93 are not great to rubbish.
If you look on the diff cap, there's a date code.
#4 ac427
ac427
  • 679 posts
Posted 03 March 2022 - 09:35 AM
Hi ac427,
Thanks MaximMini, Is there any other area of the case that i should inspect?
Thanks Spider, Is the date code easy to understand or does it require decoding?
Was production quality reduced after '93?
Edited by ac427, 03 March 2022 - 09:50 AM.
#5 MaximMini
MaximMini
  • 226 posts
Posted 03 March 2022 - 11:46 AM
This what the date code on the diff cover looks
And then there is a date stamped into the bottom of the gear casing like this
Last but not least this is how I treat the webs on my gearboxes to reduce stress risers (I hope that is what it's called in English).
#6 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 03 March 2022 - 12:16 PM
You should also check the surfaces where the drop gears are.
A usual failure is the idler gear bearing which then allows the gear to chew the casing. This can be repaired but not a happy find.
Gilles
#7 ac427
ac427
  • 679 posts
Posted 05 March 2022 - 12:16 AM
Thanks for the detailed reply MaximMini.
Do all A+ gears have the 'double groove'?
On the stress risers side, do you mean you smooth off any edges to spread the mechanical stresses?
#8 Spider
  • 14,984 posts
Posted 05 March 2022 - 08:12 AM
There was 4 different gear sets fitted to the A+ Boxes over the years.
Original standard Ratio
Close Ratio (same as the original post 68 Cooper S)
'Single Line' these had wider ratios than the original standard ratio. When they started fitting these, the previous 2 sets were dropped.
'Twin Line' these were wider again (on 1st and 2nd) than the Single Line.
There was also a few combinations of drop gear sets too.
#9 nicklouse
  • 18,642 posts
Posted 05 March 2022 - 09:19 AM
That is not any date that I know.
#10 ac427
ac427
  • 679 posts
Posted 05 March 2022 - 11:39 AM
Thanks Spider, Is there any way to tell which ratios are in a gearbox, is it just a counting gearing teeth or is there an easier way?
Edited by ac427, 05 March 2022 - 11:39 AM.
#11 stuart bowes
stuart bowes
  • 2,192 posts
Posted 05 March 2022 - 12:22 PM
The 17th of Hexember 1990
#12 Spider
  • 14,984 posts
Posted 05 March 2022 - 06:14 PM
The later sets with the lines are fairly obvious what they are.
For the earlier sets, look carefully on the Laygear, you might see a Part Number Stamped in to it;-
DAM3169   Standard Ratios
DAM3168   Close Ratios
If you can't see the number, just count the teeth on the 1st Motion Shaft (this is the first gear that drives the largest end of the Laygear) - 17 tooth is standard ratios, 18 tooth is close ratios.
I mentioned too that the drop gears came in a few ratios, the standard types have unmarked gears, there's also single line available on the Primary and Input Gears and also a twin Line Primary Gear for the 1275. These all used the same Idler Gear and give Over-drive ratios. The plain gears are 29 tooth, the single line Primary Gear is 30 and twin line Primary is 31. The plain Input Gear is 29 tooth and the single line 28 tooth. Personally, I'd suggest sticking with the 1:1 Ratios here, and changing the Final Drive ratio to get the outcome you are seeking, the geartrain losses are higher when using these overdrive gears.
Here's a cheat sheet I put together a few years back for the all synchro gearsets;-
Hopefully it makes some sense. If you look across the top, pick out which Laygear you have, then look down the column, where there's a X, that gear will fit and mesh in that set. Pretty much all the early gears go together, with the exception of 1st Motion and Laygears and in the lined sets, only lines of matching number will go together. I haven't included the drop gears as I only use the 1:1 sets.
#13 ac427
ac427
  • 679 posts
Posted 05 March 2022 - 07:24 PM
Blimey thanks Mate, That's excellent info.
#14 MaximMini
MaximMini
  • 226 posts
Posted 06 March 2022 - 08:37 AM
Nick and Stuart, you are absolutely right that this can never be an actual dated stamped in the bottom but I'm pretty sure that the last two digits do correspond to the date on the diff cover. So, it could be a four digit serial number with two digits for the year at the end, if that makes any sense.
#15 stuart bowes
stuart bowes
  • 2,192 posts
Posted 06 March 2022 - 05:03 PM
I don't pretend to know anything about it or have anything constructive to add lol I was just being silly
I thought in passing perhaps it had something to do with the week number or something but I couldn't make anything fit logically.  1990 makes sense though at the end
