The later sets with the lines are fairly obvious what they are.
For the earlier sets, look carefully on the Laygear, you might see a Part Number Stamped in to it;-
DAM3169 Standard Ratios
DAM3168 Close Ratios
If you can't see the number, just count the teeth on the 1st Motion Shaft (this is the first gear that drives the largest end of the Laygear) - 17 tooth is standard ratios, 18 tooth is close ratios.
I mentioned too that the drop gears came in a few ratios, the standard types have unmarked gears, there's also single line available on the Primary and Input Gears and also a twin Line Primary Gear for the 1275. These all used the same Idler Gear and give Over-drive ratios. The plain gears are 29 tooth, the single line Primary Gear is 30 and twin line Primary is 31. The plain Input Gear is 29 tooth and the single line 28 tooth. Personally, I'd suggest sticking with the 1:1 Ratios here, and changing the Final Drive ratio to get the outcome you are seeking, the geartrain losses are higher when using these overdrive gears.
Here's a cheat sheet I put together a few years back for the all synchro gearsets;-
Hopefully it makes some sense. If you look across the top, pick out which Laygear you have, then look down the column, where there's a X, that gear will fit and mesh in that set. Pretty much all the early gears go together, with the exception of 1st Motion and Laygears and in the lined sets, only lines of matching number will go together. I haven't included the drop gears as I only use the 1:1 sets.
Did the MG Metro Turbo gearbox get a different different set of ratios to the ones listed in your table?
Are there any external markings on a gearbox case that might show which gearset / ratios are fitted?
Edited by ac427, 06 March 2022 - 06:09 PM.
