Kad Brakes Under 10"
19 replies to this topic
#1 GermanMoreno
GermanMoreno
  • 195 posts
  • Local Club: Mainly Minis Montreal
Posted 03 March 2022 - 09:57 PM
Hello! Looking for information on what brake/wheel setup works with the KAD brakes for 10" wheels.
I know they have 2 sizes of discs and calipers, 7.75" and 7.9". I would like to know what wheels people use in combination with these brakes! Im sure some 10" wheels wont fit 7.9", I just need to know which ones. Thanks in advance!
My 2 options for wheels are 6x10 GB or 6x10 RS watanabes.
#2 imack
imack
  • 2,119 posts
Posted 04 March 2022 - 06:34 AM
I've got 7.9" KAD calipers with vented discs under 6x10 genuine minilites. Not the deep dish version but the one with more inward offset that minispares call Cooper S offset. My previous set of 5x10 GB's fitted as well.
Edited by imack, 04 March 2022 - 07:29 AM.
#3 imack
imack
  • 2,119 posts
Edited by imack, 04 March 2022 - 07:26 AM.
#4 imack
imack
  • 2,119 posts
#5 imack
imack
  • 2,119 posts
Posted 04 March 2022 - 06:37 AM
Edited by imack, 04 March 2022 - 07:27 AM.
#6 GermanMoreno
GermanMoreno
  • 195 posts
Posted 12 September 2022 - 09:19 PM
that looks quite tight but unsure if as tight as this, is this close on your end? hard to tell by the photo. Im not sure this is enough cleareance
#7 imack
imack
  • 2,119 posts
Posted 13 September 2022 - 06:08 AM
It's tighter at the outer face of the caliper, about 1.0mm clearance using a feeler gauge.
#8 GermanMoreno
GermanMoreno
  • 195 posts
Posted 13 September 2022 - 02:03 PM
Wow that's tight, no issues with balance weights? from the template placed on my wheels i can see it is about the same clearance. Its a tough call given the price of these brakes
Edited by GermanMoreno, 13 September 2022 - 02:03 PM.
#9 hazpalmer14
hazpalmer14
  • 684 posts
  • Local Club: cumbria mini cruisers
Posted 13 September 2022 - 05:08 PM
I have mini sport 4 pot 7.9" disks under mini special wheels. I took the foam backing off the wheel weights and shaved the caliper for clearance. Some people don't run wheel weights at all
#10 imack
imack
  • 2,119 posts
Posted 13 September 2022 - 06:47 PM
Balance weights obviously won't fit between the wheel and the caliper. I only do a static balance using a bubble balancer and stick the balance weights to the rim between the spokes and the caliper. Not had any balance issues.
#11 GermanMoreno
GermanMoreno
  • 195 posts
Posted 16 September 2022 - 11:59 PM
I don’t know those, what size are they?
#12 GermanMoreno
GermanMoreno
  • 195 posts
Posted 20 September 2022 - 05:59 PM
Do you know if the solid version of the brakes would have a larger clearance? I assume since the disks are thinner perhaps the callipers too?
#13 imack
imack
  • 2,119 posts
Posted 20 September 2022 - 07:10 PM
I'm pretty certain that the inner and outer caliper halves are the same for vented and solid discs. The vented versions just have the black spacer added between the caliper halves to make up the additional width for the vented discs (exactly as British Leyland did for the original metro turbo calipers)
The solid disc version will move the outer caliper half inboard by the width of the black spacer (haven't measured it but I guess it about 10mm wide) so may possibly give fractionally more clearance depending on wheel design.
#14 GermanMoreno
GermanMoreno
  • 195 posts
Posted 20 September 2022 - 08:26 PM
Thanks for your help!
I wrote to KAD about this.
I mirrored the template and i get about a bit less of 1mm clearance for the 7,9" vented. Pretty similar to the Minilites you have. Relying on a cardboard template with such a small clearance is a big gamble! specially with the cost of the kit.
#15 imack
imack
  • 2,119 posts
Posted 20 September 2022 - 09:11 PM
Found my template, I had a fancy I'd taken a chance with mine fitting. My template shows zero clearance, I was pleased to find I had 1mm clearance in reality!
