If you pick up a tough stone that lodges on top of the caliper and wedges against the rim, it could cut an Aluminium wheel in two in the same way that a stone can cut through the sidewall of a rear tyre when wedged on top of a rear radius arm.
Kad Brakes Under 10"
#16
Posted 20 September 2022 - 09:20 PM
#17
Posted 20 September 2022 - 09:50 PM
Found my template, I had a fancy I'd taken a chance with mine fitting. My template shows zero clearance, I was pleased to find I had 1mm clearance in reality!
#18
Posted 20 September 2022 - 10:34 PM
I can't see it being noticeable myself but you never know.
And the 1mm clearance is cringe worthy.
#19
Posted 21 September 2022 - 05:30 AM
1mm clearance is more than double the clearance I had for 25 years when I ran 8.4" vented discs with modified metro turbo calipers and modified 5x10 GB alloys.In reality do 7.9" discs offer any advantage over 7.5"?
There is a noticable increase in pedal pressure required going from 8 4" to 7.9" and that's a comparison using the very same pair of 8.4" discs I turned down to 7.9" and the same set of pads. KAD calipers use the same sized pistons as metro turbo too.
I'd imagine a similar increase in pedal pressure again going to 7.5"
Edited by imack, 21 September 2022 - 05:32 AM.
#20
Posted 23 September 2022 - 08:21 PM
ok amigos, I've decided to go for the 7.75" option. I'll stand on the safe side.
Once I get the brakes I'll post pics and installation updates! Thanks everyone!
